12-12-2014, 07:58 AM | #1 |
Rock Crawler Join Date: Oct 2009 Location: Columbia, SC
| The Skunk Ape....a down south Yeti.
So somehow I bought a Yeti slider off of E-bay during the frenzy of "pay now" button mashing that was black Friday/cyber Monday. I also picked up a few parts to get me going on the build. Nothing really special now but a whole heap of parts should be trickling in over the next couple of weeks. So far I have installed a STRC bellcrank set along with the VP steering posts. It all fit perfectly and REALLY beefed up the steering. A set of RPM arms also went in while everything was apart. Stuck a MIP out back too. I picked up an Axial locker and a set of the newer 94mm uni's too but I'm unsure if I want to use those or go with the D_lux Ofna setup. Heres a parts list..... Up front: STRC steering bellcrank VP steering posts Duuuuude rang RPM arms STRC caster block SSD knuckles Axial locker Axial unis McMaster M2 tool steel and alum. collars (Binaryterrors hingepin method) Axial F1 toe block BMRC stainless turnbuckle kit Axial HD gearset Out back: MIP Yeti shaft UCFAB trailing arms (anno'd version) BMRC Ti upper links D_lux U4 truss HR locker Axial UD gearset VP black lockouts VP bearing caps VP diff cover VP link mounts Trans: STRC motor mount Robinson 64t Gen3 slipper Electronics: MMP Tekin PRO4 4000kv (13 tooth pinion, plan on 3S power) CC BEC Hitec 7950th (racers edge horn) Rolling stock: Gearhead/CAC 2.2 EZ-Loc's Pitbull RBII's CI 6.0 DD's Chassis/suspension: T-Bone Racing full skid Axial alum. shock tower Axial alum. shock plates Axial alum. 4-link mounts Panels: CFM full roof Heres a couple pics until the parts start rolling in... It should be a blast scaling this thing out and beating the snot out of it. Can't wait to throw all these new parts at it and see what she'll do. _ Last edited by CREEPINKING; 01-18-2015 at 05:26 PM. |
12-12-2014, 08:21 AM | #2 |
| Re: The Skunk Ape....a down south Yeti.
nice! another ebay slider build ;) do you have a battery in it in that last pic? rear seems high? |
12-12-2014, 08:38 AM | #3 | |
| Re: The Skunk Ape....a down south Yeti. Quote:
Yours is killer! That wrap really gives it some personality. I plan on taking a few tips from what you did there. No electronics in it at all yet so she rides a little high all around. | |
12-13-2014, 08:51 PM | #4 |
| Re: The Skunk Ape....a down south Yeti. |
12-15-2014, 08:14 PM | #5 |
Got a few of the parts in today that I was waiting on. These anno'd UCFAB arms are beautiful! with the BMRC uppers The STRC motor mount and RR slipper/spur gear. BMRC turnbuckle set. These things were a pain in the rear to setup. I have a few more packages that will be coming in throughout the week so hopefully I'll have it all bolted up by the weekend and run a few packs through it. . |
12-17-2014, 05:19 PM | #6 |
12-20-2014, 02:54 PM | #7 |
E-bay is the devil. This was one of those late night why-not? kinda buys. I kinda regretted it while waiting for it to get here but it turned out to be a pretty awesome part. T-Bone Racing full skid I thought it was going to be like adding a big shovel to the bottom of my ride but it actually sits real tight to the chassis and lips up where it needs to. It eliminates all those ribs and dips in the stock chassis and strengthens it from front to back quite a bit. Plus its slicker than owl poop. Only downfall I can see so far is it makes it harder to get to the little door on the bottom. |
12-20-2014, 10:20 PM | #8 |
I've been looking at these.. More so the A-arm skid plates.. Thought they would aid in the snow, kinda like a ski would, and allow the front end to "float" around better, without digging in.. Looks clean! |
12-21-2014, 10:14 AM | #9 | |
I saw those a-arm skids too but I think they only work with the stock arms. If they are anything like this full skid they should be nice though. Should be perfect for the snow! I think I may add some chassis tape to this full skid to give it that extra little layer of protection and slickness. | |
12-24-2014, 05:21 PM | #10 |
Got a new body today and within 15 minutes of showing up it looked like this.... Trimmed on it a while and got this... It's not a great fit but it works. Only rough cut and mocked up for now. I plan on moving the rear wheel wells back a good bit and working on not having the rear look so raggedy. I also plan to do something with the front grill/headlights. Might look ok if everything works out. . |
12-24-2014, 06:19 PM | #11 |
Quarry Creeper Join Date: May 2011 Location: scituate RI
Nice looking ride. I have a full set of T bone on my summit and love them
12-24-2014, 08:18 PM | #12 |
12-24-2014, 08:30 PM | #13 |
The only thing if you use the a arm skids they do collect junk down in the arms but they do work great for keeping sticks and stuff from getting hung up in them
12-26-2014, 05:19 PM | #14 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
The spawn body looks kinda cool. Would it fit better if you put most of the wraith cage to the yeti?
12-26-2014, 06:18 PM | #15 | |
The only real issue is how narrow it tapers up at the roof, plus its a little short. If the roof and rear section of a wraith cage were grafted on it would fit perfect. I've been working on some side panels and I pulled the stickers off the grill and started something there too, just to change it up a little. I have been contemplating chopping the top completely off. Not sure though, any opinions? | |
12-29-2014, 04:11 PM | #16 |
Pebble Pounder Join Date: Mar 2014 Location: U4IA Oregon
hows the STRC steering belcrank?
12-30-2014, 12:40 PM | #17 |
| Re: The Skunk Ape....a down south Yeti. The fit and finish are great. It does a lot to stiffen up and smooth out the steering. I haven't wired the Yeti up yet so this is just from what I see on the workbench but I think it'll do really well once it sees a track. I did have to notch the duuuuuude steering lockout to get it in flush but other than that it installed without any problems. |
12-30-2014, 12:48 PM | #18 |
01-01-2015, 05:51 PM | #19 |
01-05-2015, 01:44 PM | #20 |
The Skunk Ape....a down south Yeti. - Similar Threads | ||||
F'noff the skunk way | TheSkunkBuster | Formula Offroad | 21 | 05-23-2012 12:50 AM |
South Carolina boy headed to south jersey for the week | jeremyfowler33 | New Jersey | 10 | 02-23-2012 09:58 PM |
Ape with an AK | EeePee | Chit Chat | 5 | 01-14-2012 11:33 AM |
My modified skunk | CarterFab | Losi Mini-Rock Crawler | 3 | 09-13-2010 09:13 AM |
The Skunk Build | merrillon24s | Losi Mini-Rock Crawler | 6 | 06-17-2009 07:50 AM |
