04-25-2015, 07:14 PM | #41 |
Quarry Creeper Join Date: Jun 2007 Location: Los Angeles
| Re: UCFab U4 Yeti
Just received this, a real piece of art! Too bad I'm travelling, won't be able to mount it on the chassis till June. |
04-25-2015, 07:29 PM | #42 |
RCC Addict Join Date: Dec 2012 Location: Crookston
| Re: UCFab U4 Yeti
Awesome chassis. Can't wait to see more once you get back.
04-26-2015, 07:48 AM | #43 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
| Re: UCFab U4 Yeti
Limit straps are to short but if you get creative you will find locations,does take a lot of travel out though. Tried to contact cossey mfg. but to know reply, have a feeling they know all to well,and have been told a lot. Like I said they won even respond, GREAT customer service. |
04-26-2015, 07:23 PM | #44 |
Quarry Creeper Join Date: Dec 2014 Location: Sacramento
| Re: UCFab U4 Yeti
Glad to see it's finally made it's way home. Sorry you have to wait until June. |
06-07-2015, 08:17 AM | #45 |
| Re: UCFab U4 Yeti
I've started to install the chassis. Still missing some parts, like the rod ends for the rear links. Electronics are set up. Need to cut some Lexan for the body panels and to paint the scale accessories. |
07-03-2015, 12:09 PM | #46 |
| Re: UCFab U4 Yeti
Almost done... but as I tried the truck for the first time, front and rear went opposite direction (front went forward/rear backward) I thought I just reversed the front gears and I put them back in the opposite position, I've tried again and it seems it all goes backward now (nothing to do with TX reverse setting) What am I doing wrong? I can't have the Currie back axle in the opposite position... any idea? Going in reverse is much faster than forward, also while pushing the trigger forward, there's a small delay before the car starts (like when you usually go in reverse...) Last edited by utieh; 07-03-2015 at 12:29 PM. |
07-03-2015, 04:42 PM | #47 |
Newbie Join Date: Nov 2009 Location: Minneapolis
| Re: UCFab U4 Yeti
Very cool looking ! Makes me want that cage .
07-03-2015, 05:05 PM | #48 | |
| Re: UCFab U4 Yeti Quote:
07-04-2015, 01:20 AM | #49 |
| Re: UCFab U4 Yeti Can't find this setting on the MMP, do I need the USB or Field link?
07-04-2015, 05:38 AM | #50 |
Pebble Pounder Join Date: Mar 2015 Location: france
| Re: UCFab U4 Yeti
Hi utieh, really looking nice, a question regarding the MIP center shaft you've put in : Is there enough play between the shaft and the steering bracket ? Do you still have the part # of that MIP shaft ? Last edited by le varan; 07-04-2015 at 05:40 AM. |
07-04-2015, 05:39 AM | #51 |
| Re: UCFab U4 Yeti |
07-04-2015, 05:42 AM | #52 |
| Re: UCFab U4 Yeti
sorry went to fast on the save button, look above
07-04-2015, 05:46 AM | #53 |
| Re: UCFab U4 Yeti
Yes a couple mm of distance between the MIP and the rack, I think they were originally made for the SCX10, they are quite heavy so I might go back to stock.
07-04-2015, 05:54 AM | #54 |
| Re: UCFab U4 Yeti |
07-04-2015, 06:02 AM | #55 |
| Re: UCFab U4 Yeti
I don't see how to solve this reverse problem, I'm not even sure the Castle Field link is compatible with the version of my ESC, so I'm going to order the SSD rear link and sell the Currie.
07-04-2015, 07:30 AM | #56 |
Quarry Creeper Join Date: Jun 2013 Location: Canada
| Re: UCFab U4 Yeti
Swapping any 2 of the 3 wires going to the brushless motor will reverse the direction that the motor spins, should fix your problem without reprogramming the esc
07-04-2015, 08:25 AM | #57 | |
Quarry Creeper Join Date: Dec 2012 Location: Remember, wherever you go. There you are.
You can reverse rotation with the castle link, and your computer, and keep the currie. I would sooo keep the currie. Last edited by Poprivet; 07-04-2015 at 10:37 AM. | |
07-04-2015, 09:14 AM | #58 | |
Castle Creations | Field Link Castle Creations | Downloads Last edited by nfcrockett; 07-04-2015 at 09:35 AM. | |
07-04-2015, 10:33 AM | #59 | |
07-04-2015, 10:34 AM | #60 |
| Re: UCFab U4 Yeti |
UCFab U4 Yeti - Similar Threads | ||||
Yeti 7075 trailing arms by UCfab | Erik D_lux | Chassis and Suspension | 42 | 04-12-2016 06:16 AM |
The UCFab Yeti | Wheels7 | Axial Yeti | 23 | 05-18-2015 08:08 PM |
