07-04-2015, 11:25 AM | #61 |
Quarry Creeper Join Date: Dec 2014 Location: Sacramento
| Re: UCFab U4 Yeti |
07-29-2015, 05:17 PM | #62 |
Quarry Creeper Join Date: Jun 2007 Location: Los Angeles
| Re: UCFab U4 Yeti
Almost done, need to create the skins for the body panels and install the rear MIP driveshaft. My only concern is a griding sound, I'm not sure if it comes from the pinion/spur or the transmission (rear axle doesn't seem to be the problem) Thanks for the help from gilles destijl on Vimeo. |
07-29-2015, 07:22 PM | #63 |
I wanna be Dave Join Date: Sep 2004
| Re: UCFab U4 Yeti
well its not a diff.
07-29-2015, 07:38 PM | #64 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: UCFab U4 Yeti
Just sounds like the brake loading the motor
07-30-2015, 09:41 AM | #65 |
| Re: UCFab U4 Yeti
Could it also be the spur/pinion spacing with the RRP spur gear?
07-30-2015, 09:45 AM | #66 |
| Re: UCFab U4 Yeti
you are using the RRP spur? yeah its just loud...
08-04-2015, 11:24 AM | #67 |
| Re: UCFab U4 Yeti
The Yeti made it to California and I took it for a quick ride yesterday. As I was able to reverse the ESC with the CC field programer, it is still faster going reverse than forward, I might consider buying the SSD as I don't find any solution. What 3S battery guys use? runtime on 2S with a 4200mA pack is less than 8 minutes (that's the only battery pack I've bring here) |
08-04-2015, 04:03 PM | #68 |
Quarry Creeper Join Date: Dec 2014 Location: Northern VA
| Re: UCFab U4 Yeti
For all around value and performance, I find that SMC Racing or SPC Racing are the best. I use their batteries for pretty much all my RC vehicles. 3S 7200 MaH batteries from them are $60-$65. |
08-04-2015, 04:56 PM | #69 |
Rock Stacker Join Date: Jun 2014 Location: Ontario, Canada
| Re: UCFab U4 Yeti
What radio are you using? I had a similar issue when I flipped my motor direction with my Tekin RX8. I ended up switching the direction on my radio for throttle and that seemed to work. |
08-04-2015, 05:00 PM | #70 |
| Re: UCFab U4 Yeti
Thanks for the tip hobbez84 @Hfrajuncajun, it's a simple Futaba 3PL, I first reversed the throttle from the radio, it doesn't really work since you get the small lag from when you go in reverse (doesn't sound really clear). |
08-04-2015, 05:32 PM | #71 |
| Re: UCFab U4 Yeti
I'm not sure then, sorry. I'm using a Spektrum DX3E, but I sometimes do have an issue with it not going into reverse from a stand still. Yet the ESC says it's receiving the reverse signal which leads me to believe it's an ESC issue. You may have to double check your output percentages? I don't see why if it is reversed why it would give you throttle delay. It also seems like your runtime is way low...which leads me to believe it is something else. Last edited by Hfrajuncajun; 08-04-2015 at 05:35 PM. |
08-16-2015, 10:14 PM | #72 |
| Re: UCFab U4 Yeti
So I gave up on the Vanquish and the reverse gears thing. I bought the SSD rear axle. One of the front gearbox screw was stripped and since I don't have my Dremel here, I went to a RC track in Irvine hopping someone would have one. Only one person was there, didn't have a Dremel but suggested OCRC in Huntington Beach because there were a race. Track owner has a Dremel, front gears are reversed now. I tried the truck on their smaller track. First 3 laps are a complete disaster, the car is sitting way too high, it nose dives at every jump, but after setting the ride height right and putting more speed before jumps, it does OK. 2S is perfect for this track (I'm not sure I'd be able to control it with a 3S pack) - It's been almost 20 years I haven't been on an off-road track but it jumps decently for its weight - High speed cornering is OK, just flipped once. - Tight corners with the front open diff are almost OK but I need to put less drag brake on the ESC) - There is still this horrible grinding noise when I brake (I need to check the gear mesh) - 3 shocks are leaking and I've bent the front aluminium upper link (how can I fix the leaking on those stock kit shocks?) - I get 10 minutes of run time with the 2S 4200mAh pack, I guess it's normal I guess a race track is not its natural element but it was fun! |
08-16-2015, 10:21 PM | #73 |
| Re: UCFab U4 Yeti
This is what I did to fix my shocks and it worked great. my leaky Icon shock fix Still confused how you had the power issue with the currie. Mine works fine. |
08-16-2015, 10:42 PM | #74 | |
| Re: UCFab U4 Yeti
Thaks for the tip fr8cture, I'll order it tonight. As for the Currie, I could not figure out how to reverse my ESC properly, it was still going much faster in reverse. Quote:
08-17-2015, 07:28 PM | #75 |
| Re: UCFab U4 Yeti
Faster in reverse usually means the 3 wires between the esc and motor is mixed up. once you confirm all the wires run A-A B-B C-C, then you setup throttle on the transmitter. With the currie axle, you'll need to take one more step and reverse the motor through the esc programming.
08-17-2015, 07:32 PM | #76 | |
| Re: UCFab U4 Yeti Quote:
08-17-2015, 07:34 PM | #77 |
| Re: UCFab U4 Yeti
you cant switch the motor wires with a sensored motor. Thats why it wouldnt work. EDIT:Nvm see its the stock motor. Last edited by fr8cture; 08-17-2015 at 07:36 PM. |
08-17-2015, 10:49 PM | #78 | |
Rock Stacker Join Date: Jul 2015 Location: San Jose
On a side note your Yeti looks bad ass. One of the best I've seen. Last edited by MonkeyFist; 08-17-2015 at 10:59 PM. | |
08-17-2015, 11:32 PM | #79 | |
| Re: UCFab U4 Yeti
It's a Holmes 540 Puller with MMP. Quote:
08-18-2015, 01:38 AM | #80 |
| Re: UCFab U4 Yeti
Ahh looked like the stock motor in the pic I looked at. Sent from my VS986 using Tapatalk |
UCFab U4 Yeti - Similar Threads | ||||
Yeti 7075 trailing arms by UCfab | Erik D_lux | Chassis and Suspension | 42 | 04-12-2016 06:16 AM |
The UCFab Yeti | Wheels7 | Axial Yeti | 23 | 05-18-2015 08:08 PM |
