03-21-2015, 12:46 PM | #41 |
Newbie Join Date: Nov 2010 Location: Kent
| Re: A Yeti in the Wolfpack
What MIP part number did you use for the center shaft? I can't seem to find it anywhere.
03-21-2015, 01:15 PM | #42 |
Rock Crawler Join Date: Oct 2009 Location: Columbia, SC
Some gorgeous parts you got going into this thing man! Your thread is hilarious too. One of my favorites in this section. I'm looking forward to hearing how the Holmes motor works out. It should be an absolute rocket. I've found those RR steel spurs eat pinions for breakfast, lunch and dinner so make sure to pickup some spares. The wrap looks good in the pics. If you haven't already, hit it with a hair dryer. It really helps work out the bubbles and waves. |
03-21-2015, 04:07 PM | #43 |
Quarry Creeper Join Date: Jan 2011 Location: Michigan
| Re: A Yeti in the Wolfpack |
03-21-2015, 04:24 PM | #44 | |
| Re: A Yeti in the Wolfpack Quote:
I too am excited to get that dc powered monster up and growling, but at the rate I'm going i may not be done before next winter and absolutely valid point on the robinson gears. I have had great luck running RR spurs with RR pinions with alloy mounts. that said, any deviation from that recipe has been disaster for me. the motor mount was the one that snuck up on me though, another RC guy clued me in on the flex rate and heated up properties of plastic and its neat way of letting your gear mesh kinda wander and cause you grief. once i replaced all my motor mounts to alloy my motors run a bit cooler and my gears last like you expect em to...least wise as long as i remember the lock tite | |
03-21-2015, 04:24 PM | #45 |
03-21-2015, 04:30 PM | #46 |
| Re: A Yeti in the Wolfpack nope more likely I'm a moron, as you can see i haven't had it in the tub yet so its quite possible it does not fit! of course it might....with my dumb as its always a crap shoot. But if no body answers this before hand, ill be able to tell you for sure when i try to put it in |
03-21-2015, 04:35 PM | #47 | |
Edit: This might be our best shot, though I don't know how the outputs match up: http://store.rc4wd.com/Scale-Steel-P...5mm_p_819.html Last edited by A1Fiddler; 03-21-2015 at 04:39 PM. | |
03-21-2015, 04:41 PM | #48 | |
hmm this one might be better Scale Steel Punisher Shaft V3 (3.56"-4.35" / 90.5mm-110.5mm) 5mm Hole Last edited by Rockwolf; 03-21-2015 at 04:46 PM. | |
03-21-2015, 04:50 PM | #49 | |
It looks like that RC4WD shaft I linked to should fit the transfer case output, but I don't know how the input to the front diff would work. It looks like a universal type deal instead of a standard dog bone. If I can figure out the front diff input I may give it a shot and if it doesn't work I'll just throw it in my Honcho since it's the correct length for that application. Edit: There you go, I think either would work but that one has a little more wiggle room than the 3mm of the other. Edit 2: According to the exploded view, the Yeti front diff uses a 5mm input shaft (http://www.axialracing.com/products/ax30408). In "theory" this should bolt right up, assuming there is enough clearance. I'm going to give it a shot if I can find one in stock. Worst case I just throw it in my Honcho which probably needs one anyway as I'm running the old school driveshafts on a HH 30t motor and 3s. Last edited by A1Fiddler; 03-21-2015 at 04:57 PM. | |
03-21-2015, 10:58 PM | #50 |
Newbie Join Date: Jun 2014 Location: flatland
So.... Indestructible front end, rear end, drive train, shafts, links, blah blah blah. When you going to upgrade the stuff that matters? I mean let's be real, everybody knows scale lug nuts is where its at.... Super awesome build. I will continue to by your left over to save your marriage or kids college fund or what ever. |
03-22-2015, 03:21 AM | #51 | |
Funny thing here is, really not funny at all. I'll have nearly a complete yeti in take off parts when I'm done I really wish I had known this would end up becoming my first all in build when I started, it would have been much cheaper and smarter to buy a slider or something similar! Of course just saying it would be smarter sort of counts me out! But the motor n esc has found a happy home in my Slash 4x4 MT so it's not been a total waste. | |
03-23-2015, 05:14 PM | #52 | |
03-23-2015, 05:35 PM | #53 |
Get this thing done! Needs to bash rocks badly.
03-23-2015, 06:03 PM | #54 | |
03-23-2015, 06:48 PM | #55 | |
03-23-2015, 07:04 PM | #56 | |
Edit: We previously determined that the Yeti rear shaft is far too long for the front. Unfortunately it looks like the SCX10 shafts are also too long and I have yet to find an MIP shaft that will work. I don't know if the Traxxas Slash male shaft will match up size/spline wise with the AX10 female shaft but that may be an option. We may be stuck with the RC4WD shaft. That is if we want to change it at all, but I would think it would be the weak link after changing the rear shaft to MIP and the front axle shafts to a Dlux Ofna setup. Edit 2: Here's another option. Better than the RC4WD but still not MIP. Not expensive though. http://www.junfac.com/shop/index.php...roducts_id=251 Last edited by A1Fiddler; 03-23-2015 at 08:48 PM. | |
03-23-2015, 09:27 PM | #57 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
killer build man, ill be doin most of those upgrades to lol… damn addiction
03-23-2015, 09:32 PM | #58 |
really interested in the motor, please post on how the torque is.would it not fit in the yeti?
03-23-2015, 10:34 PM | #59 |
Pebble Pounder Join Date: Aug 2014 Location: Perth Western Australia
^ x2 Was thinking the same, how is the HH Brushless motor performing? Thanks |
03-24-2015, 12:53 AM | #60 | ||
AND, thanks for stopping by and checking it out. | ||
A Yeti in the Wolfpack - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
wolfpack any good | MiddleT | Electronics | 11 | 11-07-2008 02:56 PM |
