03-22-2015, 01:31 PM | #1 |
Newbie Join Date: Feb 2015 Location: LA
| rear bevel mesh issue with vanquish axle
Hi all I've been having trouble stripping gears, and have reworked the rear now with this: Vanquish Products Wraith & Yeti Axle Black And axial HD bevel gears AX30401. What i'm finding now is that the mesh is inconsistent and my yeti is effectively FWD. There're no stripping noises, and I don't see any metal shavings, but the teeth are wearing. With the stock axle I definitely heard stripping. The rear wheels will spin under power if there's no resistance. I assume I need some kind of shim. Any recommendations? Thanks in advance |
03-22-2015, 01:48 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: rear bevel mesh issue with vanquish axle
So the rear isn't driving the rear tires? Are you still using the stock locker/spool? If so, Id bet its spinning inside its plastic housing.. |
03-22-2015, 02:11 PM | #3 | |
| Re: rear bevel mesh issue with vanquish axle Quote:
Yes stock locker, but pretty sure it's not spinning- I can feel it not quite meshing when I throttle while holding the rear wheels still. The holes for the axles look intact, so I don't think the diff is spinning free of the axles. | |
03-22-2015, 03:29 PM | #4 |
Well how does it look/feel when you've got the cover off and are spinning the pinion shaft by hand? I can't imagine it being that loose even when they are assembled with no care for how it's shimmed if at all. Did you use the gasket between the ring gear and the locker housing? It will be a loose fit with it installed as it pushes the ring gear away from the pinion. |
03-22-2015, 03:34 PM | #5 |
Rock Crawler Join Date: Feb 2014 Location: ?
Check the locker
03-22-2015, 03:56 PM | #6 |
I was wrong... frdtrkguy was right - locker was spinning in the housing. but wouldn't have believed it until i tried to take the gasket out... thanks everyone! |
03-22-2015, 05:24 PM | #7 |
Hot Racing spool. Best $15 you'll spend on a crawler. |
03-23-2015, 07:29 AM | #8 |
Rock Stacker Join Date: Mar 2015 Location: Clarksville
I've been looking for non axial/vanquish lockers. How have the HR locker lasted?
03-23-2015, 08:29 AM | #9 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Holmes Hobby and Locked up RC both sell lockers. Don't rule out the Vanquish locker either.
03-23-2015, 08:58 AM | #10 | |
I've got a HR spool in the back of my Yeti too. | |
03-25-2015, 03:10 PM | #11 |
Rock Stacker Join Date: Feb 2014 Location: Elk River
Holmes locker in mine. It was a snug fit and been holding up well
rear bevel mesh issue with vanquish axle - Similar Threads | ||||
Vanquish axle issue... | 87yota | Axial Wraith | 24 | 04-30-2013 04:00 PM |
Rear axle rotation issue | elsewhere | 1.9 Scale Rigs | 9 | 03-20-2013 07:36 AM |
Wraith Heavy Duty Bevel Gear Set - Underdrive REAR - ISSUE | slimfire | Axial Wraith | 11 | 01-24-2013 04:03 AM |
help!!! GEAR MESH IN AXLE ISSUE | mhflies | Losi Mini-Rock Crawler | 4 | 07-15-2012 06:39 PM |
rs10 rear axle issue | tpain123 | Redcat Crawlers | 5 | 05-16-2011 07:22 AM |
