02-15-2016, 08:00 AM | #1 |
Quarry Creeper Join Date: Aug 2008 Location: Sweden
| Help gearing down my Yeti / HH Pro Puller!
Hello. I need some help gearing down my Yeti running on 3S with HH Pro Puller 540XL 3500kv and Castle Mamba Max Pro ESC! Problem is it runs very hot, i could barley touch it after my last run. I run stock gears atm, should i change spur or pinion? I know nothing about gearing and need some help before getting the right gear, just need it to run a bit colder! I think the stock geras is Pinion Gear 32P 16T / Spur Gear 32P 64T |
02-15-2016, 08:32 AM | #2 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
| Re: Help gearing down my Yeti / HH Pro Puller!
You can try a 14t or 15t pinion. Many people run that motor in stock Yeti's with no problems. Some heat is normal. Can you put a temp gun on it to see exactly what temps you are running?
02-15-2016, 10:38 AM | #3 |
Quarry Creeper Join Date: Nov 2014 Location: WA
"Hot to touch" means nothing. If is under 160F you are fine. Get one of the temp guns from amazon/ebay for $10-20 and you are set. |
02-15-2016, 11:24 PM | #4 |
RCC Addict Join Date: Aug 2012 Location: Philippines
On 3000kv Pro4HD 3s & MMP I have no heat issues on stock gearing. I'd say the 3500kv Holmes could benefit from one or two teeth down on the pinion. |
Help gearing down my Yeti / HH Pro Puller! - Similar Threads | ||||
The Holmes Puller Pro BL 540XL 3500kv the YETI Grail? | npcaldwell | Axial Yeti | 164 | 03-28-2017 07:32 PM |
HH puller 540xl gearing | Mudman02 | Electronics | 2 | 07-02-2015 02:18 PM |
HH 7t Puller gearing advice | jeepster73 | Electronics | 5 | 08-07-2011 03:06 PM |
Gearing on a 7T puller? | Jakerz | Electronics | 5 | 06-08-2008 09:08 AM |
7T PULLER motor gearing | volumeone | Holmes Hobbies | 1 | 06-07-2008 11:19 AM |
