04-06-2016, 09:15 PM | #1 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Broken rear axle
My rear axle decided to break on me today. I already have the Vanquish V2 OCP on its way. I didn't buy axle shafts for the V2 because I was going to use the stocks. Now my stock shaft is bent. What is the best axle shafts to use with the V2 housing? Might as well upgrade
04-06-2016, 09:50 PM | #2 |
RCC Addict Join Date: Aug 2012 Location: Philippines
| Re: Broken rear axle
CBRB titanium from CreeperBob here on RCC. $75/ pair Sent from my SPH-L720 using Tapatalk |
04-06-2016, 09:59 PM | #3 |
Thx for the reply. I'd it best to pm him or does he have a site? Any upgrades you recommend? I have the HD gears ready for the V2 when it gets here. Should I have bought the diff cover? Have the VP lockouts and link mounts.
04-06-2016, 10:08 PM | #4 |
Just PM him. Sent from my SPH-L720 using Tapatalk |
04-06-2016, 10:14 PM | #5 |
Ok just did. I also realized the housing doesn't come with the truss. This thing is draining my bank account.lol
04-06-2016, 10:24 PM | #6 |
Yeah... VP life Sent from my SPH-L720 using Tapatalk |
04-07-2016, 09:16 AM | #7 |
| Re: Broken rear axle Sent from my HTC6500LVW using Tapatalk |
04-07-2016, 09:28 AM | #8 |
Pebble Pounder Join Date: Feb 2006 Location: Calgary 'Berta
Bummer, beef tubes for life!
04-07-2016, 05:41 PM | #9 |
Pebble Pounder Join Date: Dec 2014 Location: Duluth
Yeah, make sure to install beef tubes this time.
04-07-2016, 08:32 PM | #10 |
Vanquish V2 b here 2mrw but woulda been nice to have a spare housing in the bag.lol. I also got the titanium axle shafts ordered from cbrb so hopefully I won't b down too long...
04-07-2016, 08:38 PM | #11 |
| Re: Broken rear axle |
04-07-2016, 08:38 PM | #12 |
Gave me some time to mess around with other stuff. Trump is a joker not King |
04-09-2016, 07:22 PM | #13 |
Rock Stacker Join Date: May 2015 Location: Saint Louis, MO
I just put the Vanquish OCP on mine, haven't really taken it out and run it yet though. I'm using the SSD wide-axle kit w/lockouts. The plastic Axial truss fits just fine on the Vanquish axle. The plastic Axial diff cover doesn't fit very well on the Vanquish axle, but I was able to force it in place. I think that the bearing caps for the vanquish need to be clearanced a little to allow the diff cover to sit right. I have an AMF diff protector Amazon.com: Axial Yeti Aluminum Differential Protector (Wraps Around Pinion): Toys & Games and it locates on the ribs on the Axial diff cover. When putting the axle together the vanquish bearing caps seem a bit wide, I had to force them and the diff into the housing and it feels like it drags a bit. I'm going to run it a bit and see if it loosens up, if not I'll pull it apart and see about trimming the caps up a little. I don't think beef tubes will fit in this axle. I didn't measure but it looks like there is just enough clearance to slide the axle shafts in. I believe their description even mentions this. The vanquish instructions say to use a 5x11x5 bearing at the input. That is an oddball size and I didn't have one. Just used a 5x11x4 and a .012 shim. I don't think a 5x11x5 would fit, maybe it was a misprint??? Kind of odd because they did include the 5x14x5 bearing that goes behind it. Last edited by gman350; 04-09-2016 at 07:31 PM. |
10-21-2017, 04:21 PM | #14 |
Pebble Pounder Join Date: Mar 2012 Location: Greece
I broke two rear axles in two days.The stock axle is soft like butter.I have VP rear lockouts,VP trailing arms,VP TI upper links,VP Spool and stock rear shafts but I can't afford VP housing.I am going to buy the stock again or the Xtra Speed Steel Alloy Axle Housing.Anyone use them?Any suggestions?
10-21-2017, 10:16 PM | #15 | |
Pebble Pounder Join Date: Sep 2016 Location: SE Mo
| Re: Broken rear axle Quote:
CreeperBob's Titanium shafts. Sent from my Nexus 6P using Tapatalk | |
10-22-2017, 01:22 AM | #16 | |
RCC Addict Join Date: Jun 2016 Location: Germany
if stay with stock get some beeftubes so the plastic don't move + creeperbobs ti axles. Gesendet von meinem T1-A21L mit Tapatalk | |
10-22-2017, 04:39 AM | #17 |
WHITE-TRASH above says Titanium shafts brake.Anyway I haven't problem with shafts.yes they bend but only when the axle brake.Then I straighten them.Chinese xtra speed axle housing are they good?
10-22-2017, 05:18 AM | #18 |
beeftubes and new housing if nessesary are cheep and the beeftubes will solve the axle breaking issue. no expearience with the xtra speed housing, but with parts from them. they use weak alloy and fitment is sometimes not perfect. from this, on some places they are exaptable for me on same not. the ssd is the best rear axle in my eyes, but you will lose the invested $ cause it eleminates the need of lockouts and the need of wider hubs in the rear, also has bigger inner bearing on the diff input and centered diff. many benefits beefup the rear in my eyes. they now come with the hd shafts. but never bend the stock ones till now Gesendet von meinem T1-A21L mit Tapatalk |
10-22-2017, 04:24 PM | #19 |
I will buy beef tubes and the stock axle for now.Does the tubes need any drilling to fit the shafts in? I had bought xtra speed tubes for my bomber but rear shafts were bigger than the tube holes and I had to open bigger holes.
10-23-2017, 12:24 AM | #20 |
I had to drill the housing with a 9mm drill to fit the tubes. if i remember correct
Broken rear axle - Similar Threads | ||||
Broken pin in rear axle driveshaft cup. | krazykrawler | Vaterra Ascender | 3 | 01-06-2016 08:17 PM |
Broken rear axle gears | motojeep | Axial XR10 | 9 | 04-18-2013 09:28 AM |
Broken Rear axle help... | Zuk Jr. | General Crawlers | 3 | 11-10-2006 03:10 PM |
Broken Rear Axle | scout21972 | General Crawlers | 3 | 02-16-2006 08:33 AM |
