11-28-2016, 11:44 AM | #1 |
Rock Stacker Join Date: Aug 2016 Location: Maine
| After market front tires are rubbing Installed proline Denali's front and rear. On the front the nut carrier hing pin rubs when turning. Anyone else run into this? |
11-28-2016, 11:46 AM | #2 |
RCC Addict Join Date: May 2009 Location: Weston
| Re: After market front tires are rubbing
Yup, those wheels might work with a wider hex. You should have got wheels that take an SLW hub so you can change the offset.
11-28-2016, 11:49 AM | #3 |
There's a set of Traxxas hexes that are a little wider. But they're plastic.
11-28-2016, 02:28 PM | #4 |
RCC Addict Join Date: Jun 2016 Location: Germany
searching for some parts i found these recently Boom Racing Aluminum Wheel Widener (4) (Offset: +14mm) Orange [Recon G6 The Fix Certified] BRSCX46 but i have no experiences with them. |
11-28-2016, 02:58 PM | #5 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
I did away with the screw and nut completely. Drilled out the a arms for slash hinge pins from lunsford...
11-29-2016, 06:53 PM | #6 |
SO buddy had the thicker traxxas hexes. Got those on for now and trimmed the nut/bolt a little. Will work for now. Those Lunsford hinge pins what length will I need I can find a 30.5 and a 31mm also the description on towerhobby says they are 3mm pins why did you need to drill out the arms? |
11-29-2016, 07:03 PM | #7 |
Newbie Join Date: Jun 2015 Location: SoCal
| Re: After market front tires are rubbing |
11-29-2016, 08:08 PM | #8 |
11-29-2016, 09:53 PM | #9 |
Quarry Creeper Join Date: Jul 2013 Location: PA
Team KNK makes wider hex's
11-30-2016, 12:10 PM | #10 |
| Re: After market front tires are rubbing lol Don't we've all been there http://www.teamknkhardware.com/apps/...1402856?page=1 From 6mm wide to 12mm wide, didn't know these existed, thanks Lanky! |
After market front tires are rubbing - Similar Threads | ||||
Front lower links rubbing driveshaft? | rngrchad | Axial RR10 Bomber | 3 | 06-12-2016 07:41 PM |
Mounting Rubicon body. Front tire rubbing bumper when turned ... | flarezfx | Paint and Body | 5 | 12-11-2013 06:24 PM |
XR10 front tires rubbing shocks | traxxasemaxxer | Newbie General | 10 | 10-07-2012 08:44 PM |
wheel rubbing on front of hilux | j4k3 | Axial SCX-10 | 5 | 08-08-2010 12:05 PM |
Tries Rubbing on front links? | Stephen25 | Axial AX-10 Scorpion | 5 | 06-28-2009 07:28 PM |
