10-04-2020, 01:15 PM | #1 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
| 17mm Hub Adapter?
Anyone convert their Yeti's 12mm hexes to 17mm? If so, id be thankful to see what you used to do it. I'm hoping to be able to swap my wheels/tires from my UDR onto my Yeti. Thanks. |
10-25-2020, 08:18 AM | #2 |
| Re: 17mm Hub Adapter?
I adapted my clod from 12mm to 17mm i used a 12mm to 17mm adaptor that slides over the 12mm hex and then just bolt on your 17mm hubs Remeber if you go this route use lock tight on the barrel nut that holds the adaptor on And theres always the easy way just buy 17mm hexs |
10-25-2020, 11:38 AM | #3 |
Hot racing makes a SC 17mm adapter for those trucks, would work the same on yours. Would be wider though by 1'each side unless you run buggy wheels
10-25-2020, 02:19 PM | #4 |
Rad. Thanks guys.
17mm Hub Adapter? - Similar Threads | ||||
Problems w/ Hot Racing 17mm hub adapter set | Trifish | Axial Yeti XL | 5 | 06-06-2016 04:33 PM |
12mm-17mm adapter | NoblesvilleKid | General Crawlers | 6 | 07-03-2008 07:40 PM |
adapter 14mm to 17mm | jevyguy | Tires and Wheels | 3 | 07-13-2007 07:54 PM |
14mm to 17mm hex adapter | Unholy | General Crawlers | 12 | 09-29-2006 10:35 PM |
