11-25-2013, 03:54 PM | #21 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: AR60/Wraith Servo/Truss/Link mount
Good eye. I noticed that after placing a servo in position and it was 1/8 off of the axle. Oops! I am thinking about using it to lay the servo down like TotoRax did.
11-25-2013, 05:20 PM | #22 |
That would be cool. Let me know what you come up with.
11-27-2013, 08:10 AM | #23 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
Will this kit fit a bigger servo like a 7980TH?
11-27-2013, 08:25 AM | #24 |
Its possible but it will take some effort. The holes for the servo posts line up with the smaller servos so it will just take some manipulation of the servo posts.
12-12-2013, 05:44 PM | #25 |
| Re: AR60/Wraith Servo/Truss/Link mount Here it is.
02-12-2014, 08:10 AM | #26 | |
Pebble Pounder Join Date: Dec 2013 Location: Gold Coast, AUSTRALIA
Hopefully there is more options planned for this orientation of servo Mount as I quite like the idea of having the servo lower, keeping it from contacting the chassis all the time. Keep up the good work. | |
02-12-2014, 03:14 PM | #27 |
| Re: AR60/Wraith Servo/Truss/Link mount |
02-12-2014, 06:22 PM | #28 |
Yeah, 7950 is direct bolt in.
02-12-2014, 06:23 PM | #29 |
02-20-2014, 09:49 AM | #30 |
Now shipping are the new full length, lockout to lockout, chub to chub carbon fiber trusses. This should significantly help or end breakage on the plastic housings. The front truss not only strengthens but it also acts as a servo mount and an adjustable upper link mount. A piece of 1/4" Delrin has been added to reenforce the area where these housings most commonly break. These are available on my website in the XR/Wraith category. dluxfab.com/products The rear truss also strengthens the entire housing while adding upper link adjustments. |
02-21-2014, 10:18 AM | #31 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
Are these still available? Does the front truss cause any issues with a CMS setup?
02-21-2014, 11:01 AM | #32 |
Yep, still on my website. I am not sure on the CMS setup. The truss was made to run the servo on the axle/truss. |
02-21-2014, 06:44 PM | #33 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
Super excited.... mine should be here tomorrow!! Thanks again Erik . |
02-21-2014, 06:48 PM | #34 |
Awesome! Cant wait to see what you think!
02-26-2014, 06:18 PM | #35 |
Rock Crawler Join Date: Feb 2012 Location: OC
YES! Got my shipping conformation for my parts!!!! CAN'T Wait! That was a fast order process, you will be seeing more of my cash soon, just need to get some first! lol Thanks Erik! |
02-27-2014, 10:43 AM | #36 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
PM'd ya, i'm wanting a set of the extendeds as well as abearing mod
03-07-2014, 09:34 PM | #37 |
Newbie Join Date: Mar 2013 Location: Elkins, AR
Just wanted to say your front and rear link mounts are working great for me. The separation of the rear link has helped with stability of my rig also as said is your build thread. THANKS
03-09-2014, 08:48 PM | #38 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
In post 30 you show the truss version with a servo mounted. Can you tell me the distance between the top of the axle tube and the top of the servo horn please.
03-09-2014, 09:54 PM | #39 |
Thats not my axle but mine measures .850 from the top of the tube to the top of the horn. Thats wheels axle and his is spaced .250 higher than mine so it should be real close to an inch or a hair more. If you need something more exact, maybe try PMing him or ask in his thread? I hope that helps. |
03-18-2014, 07:58 AM | #40 |
I am going to add in some small plastic 1/8" spacers on the Ultra front truss. We added a lot of pre load on the truss so that it would make it stronger. After beating on the tubes so much it did make everything stronger and eliminate breakage but it stresses the chub screw a bit too much. BTW, a brass insert is bad ass for the chub screw. I will revise the truss so it does not use the spacer on later trusses. |
AR60/Wraith Servo/Truss/Link mount - Similar Threads | ||||
GCM 4 link truss mount for Axial | Generis | Chassis and Suspension | 6 | 02-18-2011 02:19 PM |
