Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Duratrax Cliff Climber
Thread: 4wd?
Old 07-09-2009, 04:19 PM   #1
Default 4wd?
when i am driving my cc i only have power to the front right and rear left tires. is this normal or is something up with this?
orangecc is offline   Reply With Quote
Old 07-09-2009, 04:57 PM   #2
I like to #*&^
lockers are stripped out
2500hdon37s is offline   Reply With Quote
Old 07-09-2009, 05:09 PM   #3
Yeah, the cliff climber has no diffs in the axles, so if a left tire spins, the right should also. Might be the drive cups, hear any clicking? Has it always done this or started recently?
Jamus is offline   Reply With Quote
Old 07-09-2009, 05:29 PM   #4
i just got it a little while ago and it has done it since day 1. so is there anything i could do about it or do i need to buy stuff for it?
Old 07-09-2009, 05:51 PM   #5
I joined the Band!
you most likely are going to have to take the axles apart to see what the problem is
proraptor is offline   Reply With Quote
Old 07-09-2009, 05:55 PM   #6
ok thanks for the help
Old 07-09-2009, 06:21 PM   #7
Mine did the same from day 1. Go ahead and buy the steel cups and use Orings on the axles.
E4x4Eric is offline   Reply With Quote
Old 07-09-2009, 06:46 PM   #8
Mine made it a couple days. I have nothing against the truck itself but there is too much plastic inside the axle! Oh well steel will be going in soon.
FlexdXJ is offline   Reply With Quote
Old 07-09-2009, 08:12 PM   #9
My axles already had o-rings in the stub shafts. That may be the difference, but with 4" tires I've had no trouble. Though the axles are stonger than the stall point of the motors on 7.2V.
