12-03-2010, 09:08 PM | #41 |
Quarry Creeper Join Date: Sep 2009 Location: Vancouver,Canada
Wow this is driving me way to nuts. Still the same problem i'm ready to crawl but when i turn system on everithing is ok than the dig servo wil go through switching phase than when i put gas ax10 moves a bit then the steering servo twitches and after all this tekin fxr all light will start to flush!!! using the same diagram as posted in my thread before , battery pack Brand new 3S ,bec set at 6.4v sterring servo 7950 dig servo 5245.i'm going nuts now. I did bind properly,calibrate radio properly and calibrate esc as well.now this issue. |
12-03-2010, 09:12 PM | #42 |
everithink works good for about a minute or two then all light on esc will start flashing. Fxr manual says that "No radio signal,check radio system" anyone has idea what that could be? I tried different rx the same think happends |
01-28-2011, 11:02 AM | #43 | |
Looking for new Trails Join Date: Dec 2008 Location: GPS locating signal.....
I have my bec hook up this way and at low throttle i have a glitch ??? | |
01-28-2011, 11:03 AM | #44 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
02-03-2011, 01:19 AM | #45 |
Man this is nuts still solving these problem just got back from garage! I'm using DX3R and steering servo 7950 and dig servo 5645 and using wiring as above but got problem when i pluged everything in it's all good untill i start to play with dig than it starts to twich and then rx light will dimm and flash then i unplug lipo. Mine frame rate is 5.5 ms Rx is good when i un[lug dig servo it's all ok also in my buggy servo works np so i have no clue what the f is going on i want to go out and finally scrach the crawler. Need help please and thank yu cheers using this diagram CCBEC set for 6.4v for testing only if all works then i'll set it to 7.4v Last edited by cliffhanger007; 02-03-2011 at 01:23 AM. |
02-03-2011, 01:28 AM | #46 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
Maybe your battery is dead? If you hit lipo cutoff on the FXR it will stop working, but the steering servo will still run since it's wired right off the battery.
02-03-2011, 01:35 AM | #47 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
Your frame rate needs to be changed to 11ms
02-03-2011, 09:02 AM | #48 |
batteries are fully chrged and will change frame rate to 11 ms. and will try later and post some pictures to also ccbec is lit up green.
02-03-2011, 09:40 AM | #49 |
does anyone pulls red wire from esc before you plug it in rx to get this working or all of you using red wire as well?
02-03-2011, 05:46 PM | #50 |
With the diagram you are using, you need to keep the red wire from the ESC to the receiver. This will provide power to your dig servo.
02-03-2011, 07:00 PM | #51 |
yes i do that but after a playing with dig for a minute or so tha Rx light will dimm and fxr light will all flash |
02-03-2011, 07:02 PM | #52 |
Well, did you try it set at 11ms yet? Also, double check to make sure you have all the connectors correctly orientated on your receiver.
02-03-2011, 07:09 PM | #53 |
Is this the same dig servo that got hot when you had it wired the Castle way? If so it probably got fried from the 7.4v's.
02-03-2011, 07:09 PM | #54 |
my Rx sits on top of dig servo is that OK?
02-03-2011, 07:11 PM | #55 | |
using the same servos as in picture above. when i hook the 5645 to steering on rx it works no problem just having problem to work this set in dig! | |
02-03-2011, 07:13 PM | #56 |
02-03-2011, 07:14 PM | #57 | |
Casey | |
02-03-2011, 07:31 PM | #58 |
at 11ms lasted about 4 mints and did the same!!! rx light dimmed and all leds on esc started to flash!!! |
03-18-2011, 04:30 PM | #59 |
03-23-2011, 08:36 PM | #60 |
man i went out with my crawler today and when i got to rock all was good and after 25 sec. everything started to twitch this is driving me nuts. I got bec set for 6.4 volts i'm using 3s lipo and power. And when it started to twitch all leds started to flush on my tekin fxr. Bec is plug directly into rx and red wire from esc is out.dig pluged in aux any one has a clue whats happening?Thanks any help will be greatly appreciated got comp on Sunday. |
