01-19-2011, 08:54 AM | #61 | |
01-19-2011, 09:34 AM | #62 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
| OK, PLEASE READ: Here's the skinny from Castle. 1st off, I'd like to thank Greg, from tech support, he was VERY helpful, professional and eager to help get the problem resolved. He is sending a NEW BEC out today with a return mailer for the one I just got last week. I am including a copy of the receipt as well. They will have to check and see of course as to what went wrong with it but Greg said they haven't had any calls on BEC's lately. So, IF there truely is a bad batch they would like to know about it so that they can make it right. They want us to be happy with their CC, products, so if you have what you feel is a bad BEC, give them a call at 913-390-6939, press 1 for tech support. I talked to Greg. That being said, Greg told me that "ONLY" the RED POWER WIRE, needs to power the servo directly, and that the signal AND ground wire should go to the rx for a true ground. I told him I would share that info and maybe getting the correct info out there would keep guys from blowing BEC's. He said, "it could be just a matter of time before the BEC goes if they are wired the way we have been doing them". (for who know's how long) I told him my 7950 has been wired the wrong way then for 2yrs and I've beat it in the heat pretty hard and it's still good. However, I'm going to change the plug to only the power wire going to the servo's power wire and the signal and ground from the servo will go to the rx from now on. Last edited by Krakker; 01-19-2011 at 09:37 AM. |
01-19-2011, 09:39 AM | #63 | |
Ill give him a call since he was the one I spoke to last week about all mine. Thanks for the # | |
01-19-2011, 09:42 AM | #64 |
RCC Addict Join Date: Feb 2006 Location: ccxc
Mines wired the other way with no issues. Hmm. Isn't a ground a ground? I might be missing something but why is the receiver ground any different from the servo ground?
01-19-2011, 09:43 AM | #65 |
JRH, what are your thoughts on this. I can wait on the rear servo since it's fine for now, should the wires be wired like Greg said??? |
01-19-2011, 09:45 AM | #66 |
oops double post ....... damn work pc
01-19-2011, 09:57 AM | #67 |
Quarry Creeper Join Date: Mar 2010 Location: Bridgeport, CT
Thats great info. I was also concerned and curious as to why or how you were wiring a bec directly to a servo. I was always against doing that.
01-19-2011, 10:06 AM | #68 |
| For the demand that today's HT servo's put on the rx's it's best to put the correct deticated power to the servo. Even Greg at CC recommended this.
01-19-2011, 10:13 AM | #69 |
I just spoke to Thomas over at CC and got similar info but was told different about the ground. He said we should be wiring: red bec to the red servo ...... black Bec to the black Servo ...... signal wire from the servo AND the black from the servo should be going to the RX only bec ground needs to be grounded To/Through the servo with the servo using the RX to ground both. http://www.castlecreations.com/suppo..._bec_setup.pdf Gonna try it tonight ................... Last edited by Robbob; 01-19-2011 at 10:38 AM. Reason: added link |
01-19-2011, 10:18 AM | #70 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
I will rewire mine tonight to send the signal and ground back to the receiver, but I still don't think that is the problem. I have had mine wired "incorrectly" for a few years and have never had any problems until just recently. And for them to say that they have not had any calls about bad BEC's lately is total BS, because I just talked to somebody there last week and sent them a bad BEC. I am still playing around with making sure I have absolutely no binding or drivetrain issues, but my steering still has issues that it never had before.
01-19-2011, 10:59 AM | #71 |
01-19-2011, 11:04 AM | #72 |
Rock Crawler Join Date: Jun 2010 Location: SENECA
01-19-2011, 11:10 AM | #73 |
That wiring diagram is interesting. I ran over a year with it the normal way. I will rewire if this one xplodes. I just don't see that being the fix.
01-19-2011, 12:19 PM | #74 |
I have to wait until I get home so I can wire up the bec and check the voltages with loads. I will do a little YouTube video. Just remember, when you plug an Esc with a built in bec into a rx, the rx is powered by the bec in the esc. If you plug a separate bec straight into a servo using the red wire, you will also be powering it. This will give you an over voltage because you are powering it from 2 places. You need to remove the red wire from the Esc to disable the internal bec. Of course there are esc's without bec's so this is a non-issue and some of you already know this info. But, after reading around a bit I realize that some are not aware of this. |
01-19-2011, 12:19 PM | #75 | |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
Any concerns ? I have yet to try this . I am having same problem, Only I run my front and rear hitec 7995 steering servo's direct of the CC bec and just the white signal wire into the Spectrum rec. My Rec get's power from the same bec . Esc red wire removed gets power from the 3s I am running a 8lbs tube buggy 2.2 wheels and my system still cuts out do us dual HT servo guys need 2 bec's now ! ? Last edited by toy4crawlin; 01-19-2011 at 12:33 PM. | |
01-19-2011, 12:32 PM | #76 | |
My experience with Thomas has always been painful, he doesn't listen and he has been wrong. Also is very rude. I cant remember the other names, but the other guy there is much more helpful and accurate. Polite as well. Also FYI, in ANY customer service ANYWHERE ! Dont accept the first answer you are given, it usually takes 3 or more tech to get you the correct answer. | |
01-19-2011, 12:54 PM | #77 | |
RCC Addict Join Date: Jun 2005 Location: St. Albans
My original BEC is still going strong and it has been seriously abused. Its been in at least 4 different 2.2 comp trucks, a super in which it powered 2 high torque airtronics servos, and lastly in my 2.2 scaler powering a 5955 hitec before it went into my losi again. Its been completely submerged in liquid electrical tape twice to water proof it and it has been completely submerged in water numerous times. The one that let me down was taken out of the package and the shrinkwrap was changed to black and installed the exact same way. Lasted less than 10 minutes. I really believe they have some bad components in the newer ones. Unfortunately, I dont keep most of my receipts to take the "angry old lady" factor out of the hobby, so I'm eating this one. | |
01-19-2011, 01:19 PM | #78 | |
IF I cahnge to a 7950 for the rear later on, I'll definantly use a seperate BEC to power it. I'm still really curious as to how we've all had perfectly fine working servo's with them direct wired like we've been doing for years. | |
01-19-2011, 01:22 PM | #79 |
REST IN ALOHA CHIP Join Date: Nov 2005 Location: *
sounds good.
01-19-2011, 01:50 PM | #80 |
| Because the battery is the common ground as JRH said earlier. I dont buy CC's answer that we are wire them incorrectly. I think it's their attempt to not tell us they are having issues. The fact that Robbob said he called them and then they tell Krakker they havent had any calls about the BEC lately says it all...
