Thread: BEC-servo stall amps
Old 01-01-2012, 07:28 AM   #1
Default BEC-servo stall amps
Hi, if a servo draws 2A at stall, would a 5A bec be strong enough ?
rhino20 is offline   Reply With Quote
Old 01-01-2012, 08:49 AM   #2
Default Re: BEC-servo stall amps
Likely, it depnds on the volts it's set for.
I have seen where some say there is a watt limit on the BEC (at least for the CC 10A BEC). Thus it's a function of volts & amps.
You must have a small servo, most servos used for steering will pull a lot of amps when stalled.
Charlie-III is offline   Reply With Quote
Old 01-01-2012, 09:01 AM   #3
The 2A stall is the figure given for a Hitec hs 5755,a 330oz@6v,which is why i was checking if a 5A bec was enough.
In theory it should be.
A castle bec + program card is nearly $60 here in europe !!
Old 01-01-2012, 09:15 AM   #4
Hmmm.....I don't know for sure, but I would have guessed a 5755 would pull a ton more amps when stalled.
BEC-servo stall amps - Similar Threads
Servo stall :( vodka child Electronics 9 09-17-2010 06:03 PM
Servo amps & voltages ... specific questions Locked Up Electronics 5 02-22-2008 02:00 PM
servo stall? ClodMaxx Electronics 6 02-12-2008 03:13 PM
Axle Stall (clod stall) TheRangerman0 General Crawlers 2 03-31-2006 11:23 PM
