01-01-2012, 07:28 AM | #1 |
Newbie Join Date: Dec 2011 Location: NL
| BEC-servo stall amps
Hi, if a servo draws 2A at stall, would a 5A bec be strong enough ?
01-01-2012, 08:49 AM | #2 |
| Re: BEC-servo stall amps
Likely, it depnds on the volts it's set for. I have seen where some say there is a watt limit on the BEC (at least for the CC 10A BEC). Thus it's a function of volts & amps. You must have a small servo, most servos used for steering will pull a lot of amps when stalled. |
01-01-2012, 09:01 AM | #3 |
The 2A stall is the figure given for a Hitec hs 5755,a 330oz@6v,which is why i was checking if a 5A bec was enough. In theory it should be. A castle bec + program card is nearly $60 here in europe !! |
01-01-2012, 09:15 AM | #4 |
Hmmm.....I don't know for sure, but I would have guessed a 5755 would pull a ton more amps when stalled. |
BEC-servo stall amps - Similar Threads | ||||
Servo stall :( | vodka child | Electronics | 9 | 09-17-2010 06:03 PM |
Servo amps & voltages ... specific questions | Locked Up | Electronics | 5 | 02-22-2008 02:00 PM |
servo stall? | ClodMaxx | Electronics | 6 | 02-12-2008 03:13 PM |
Axle Stall (clod stall) | TheRangerman0 | General Crawlers | 2 | 03-31-2006 11:23 PM |
