Thread: Are Lipos Dangerous??
Old 01-08-2012, 06:39 PM   #1
Default Are Lipos Dangerous??
I bought a new Axial Dingo. My son has a Redcat RS10XT. i am wanting to upgrade to lipos. I want longer run time, would like to get 60 mins plus on a battery. I don't know what the smallest battery I could do that with but I know I could do it on 2s 20c 5000 lipos. lipos appear to be about 1/2 the money as a NiHm. I was all set to order when the search happend just one more time....that when I read of small explosion, fire, problems. are these safe or what? sky lipos good? should I go hard case or regular? I Know the kit I bought has the 2.4 radio so Im 99% sure it has the upgraded esc. if it doesnt I will buy a lipo cut off also. btw I also plan to get thunder ac6...
jshull is offline   Reply With Quote
Old 01-08-2012, 06:42 PM   #2
Default Re: Are Lipos Dangerous??
If you take care of them then they are relatively safe. Its when you over charge them or over discharge them that you will run into problems.
Check out the stickies in this forum and you can read all about it! Or try the search feature in the upper right...This has been gone over before.
SMR 510RR is offline   Reply With Quote
Old 01-08-2012, 06:47 PM   #3
They can be when not taken care of properly, it's just when you don't know what you are doing that you run into problems, also make sure to buy a lipo safe bag as this is good back up. They sell them on the same sight you are getting the charger
Krawler23 is offline   Reply With Quote
Old 01-08-2012, 06:54 PM   #4
666
MODERHATER™
666's Avatar
I have had a nimh pack burn up a rig before. Never with a lipo! I think it's a toss up really.
666 is offline   Reply With Quote
Old 01-08-2012, 07:03 PM   #5
dezfan's Avatar
Lipos are not dangerous.
Plus they are smaller, lighter, and more energy dense.
dezfan is offline   Reply With Quote
Old 01-08-2012, 07:26 PM   #6
Funny I have charged a lipos with a car charger, shorted them, etc..... never had one catch fire.
I had nimh batteries charging on the wall and both batteries exploded literally blowing off the wall and just missed my head.
As already said just take car of them.
holycaveman is offline   Reply With Quote
Old 01-08-2012, 07:31 PM   #7
dezfan's Avatar
Plus your boy can run lipos on his rig as well, just need an in-expensive Lipo alarm as the ESC in his rig doesn't have an LVC.
2s-4s RC Lipo Battery Low Voltage Buzzer Alarm | eBay
Old 01-08-2012, 07:36 PM   #8
Just dint poke holes in them and you will be fine.
rockn is offline   Reply With Quote
Old 01-08-2012, 07:40 PM   #9
just bought a pair of the low volt alarms. guess im vested now!
Old 01-08-2012, 07:41 PM   #10
dezfan's Avatar
Welcome to the sickness.
Old 01-08-2012, 07:45 PM   #11
Don't short , don't poke holes, don't overdischarge (under 3.00v per cell), use correct charger and you will be fine
BL-4x4 is offline   Reply With Quote
Old 01-08-2012, 07:46 PM   #12
I had low volt on a lipo so i try-ed to trick my charger to charge it bad idea it blew up the lipo that is at least i had it in a tin can. just allot of smoke and made a burn mark where it was sitting
Old 01-08-2012, 07:47 PM   #13
When you store your LiPo's, add a little electrical tape over the balance tap and the connector if you have more than one in the bag. Had one puff up on me the other day, one of the connectors (micro deans) had managed to bridge one of a 2S packs cells through the tap. No fire, just a puffed cell.
Sent from my Desire HD using Tapatalk
Rockfrog is offline   Reply With Quote
Old 01-08-2012, 07:50 PM   #14
As already posted just take care of them and do not what so ever overcharge them or poke hoes!! i have had two burn up and let me say wow they get hot and smoke bad!!! but one of them was my fault i charged at to high of a rate.
BRANDON1987 is offline   Reply With Quote
Old 01-08-2012, 08:04 PM   #15
I ordered a thunder ac6 and 4 sky hard 2s 20c 5000 lipos. im ready now!
Old 01-08-2012, 08:06 PM   #16
dezfan's Avatar
Set!
If you need any help w/ connectors, let me know.
Are Lipos Dangerous?? - Similar Threads
New on Lipos, how to no waste money in overpowered LIPOS. raolguio Electronics 6 11-03-2010 03:08 PM
Is RC Rock Crawling Dangerous? ARC MotorSports Chit Chat 13 10-04-2010 01:18 PM
Hunting, can be dangerous. caymin last Chit Chat 23 06-25-2009 11:13 PM
Ok... How Dangerous are LiPo Batteries really? HaSharetz Electronics 17 06-19-2008 02:05 PM
