01-11-2012, 07:53 PM | #1 |
Newbie Join Date: Jan 2012 Location: roswell
| novak 55t....why is reverse so slow
I have a novak 55t in my ax10 for some reason my reverse is extremly slow....it will barely move. Anyone have any clue what would cause this?
01-11-2012, 07:54 PM | #2 |
Rock Crawler Join Date: Nov 2009 Location: poteau
| Re: novak 55t....why is reverse so slow
could be anything from bad motor to esc/radio settings. need a little more info. what esc, radio, how old is the motor?????
01-11-2012, 07:59 PM | #3 |
I have a Mamba max esc. The motor has only been used for alittle over a month and on still using the stock axial radio
01-11-2012, 08:01 PM | #4 |
start by checking that your throttle trim is set to center. if it's way off it can cause that. also if you have the castle link check the settings in the esc. my mmp has settings for reverse strength and brake-reverse throttle curves. if they have been changed or lost their settings it will cause no reverse. that would be a start.
01-11-2012, 08:10 PM | #5 |
I hooked it up to castle link tonight. And the reverse was set at 100 percent. The throttle trim is also set to center. Is it possible that the motor is going bad?
01-11-2012, 08:18 PM | #6 |
that's what it sounds like to me. is the throttle trim on the radio set to center?
01-11-2012, 08:28 PM | #7 |
Yes its set to center.
01-12-2012, 12:23 AM | #8 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Have you checked what the timing on the motor is set to? If its set to a lot of advance it will be slow in reverse. If you aren't sure how to check the timing, have a read of this thread: Caring for your new Brushed motor Last edited by WIDELOAD; 01-12-2012 at 03:38 PM. |
01-12-2012, 06:36 AM | #9 |
That was the problem. I took the timing out and its back to normal....thank you both for the advice
novak 55t....why is reverse so slow - Similar Threads | ||||
ae1 reverse is slow! | bikerpyro | Electronics | 1 | 06-26-2011 07:20 AM |
Slow Forward, Fast Reverse | buzz1436 | Electronics | 4 | 04-10-2010 08:51 AM |
slow reverse...? | boosst | Team Losi Comp Crawler | 7 | 06-21-2009 08:11 AM |
HELP! Reverse slow. | MISFITCOMPER | Team Losi Comp Crawler | 9 | 06-03-2009 01:59 PM |
Ax-10 slow in reverse | 8upboyz | Axial AX-10 Scorpion | 5 | 05-12-2009 01:50 PM |
