01-12-2012, 12:09 PM | #1 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| 4PL losing signal
Ok, so i did a search with no such luck. the problem i am having is that the receiver loses signal while my stuff is just sitting on my bench. I have everything on, everything functions as it should. but it loses signal for about 2 seconds every 45 to 60 seconds. it does this while it is sitting on my bench while i just sit and stare and it does the same while driving. also this is hapening on two seperate vehicles (separate receivers same transmitter) This is quite frustrating!!! HELP! |
01-12-2012, 02:03 PM | #2 |
| Re: 4PL losing signal
When you say, "Lose signal", what do you mean? Do the lights/LED's go off? Does the ESC reboot/chime? Does it do the same thing outside? Do you have any 2.4ghz things around, like a wireless network router? Are the TX batteries good? Do they both have the same type/brand/model ESC? If so, what? |
01-12-2012, 05:19 PM | #3 | |
| Re: 4PL losing signal Quote:
When everything is on and running proper the rec (futaba R2104GF S-FHSS) has a green light that is on. When the problem occurs the light goes to red and the truck loses function (throttle and steering) but the lights on the speed control stay on so it still has power. this has happened at the track with 2 seperate vehicles with their own receivers as well as on the bench at my house. | |
01-12-2012, 07:43 PM | #4 |
It really sounds like you need an external BEC (most of us use a Castle Creations 10Amp BEC) because you are experiencing RX "brownout". This means you are overdriving the ESC internal BEC, thus the RX sorta dies along with everything else. Do a search in this forum for brownout. |
01-12-2012, 07:59 PM | #5 |
I understand the theory behind using a BEC, got one on my other rig. but it does not make sence how this is happening while my rig is sitting idle on the bench???
01-12-2012, 08:02 PM | #6 |
Also i only have a cheap traxxas servo in it as well
01-13-2012, 07:07 AM | #7 |
OK, I looked over the 4PL manual here.... http://manuals.hobbico.com/fut/4pl-2_4ghz-manual.pdf Page 23 shows that the red LED means no or weak TX signal. I would check each battery in the TX (even new ones can be bad) as well as the connection from the batteries to the battery tray. This makes sense since 2 different rigs do the same but it's the same TX. Last edited by Charlie-III; 01-14-2012 at 07:04 PM. Reason: Changed RX to TX....sigh...... |
01-13-2012, 02:45 PM | #8 |
Sounds like that could possibly be the culprit. I do not have the manual to check (now i do ) I will try new batteries this weekend. Thanks for the help Charlie-III |
01-13-2012, 05:02 PM | #9 |
Hope it helps....if not, my son runs a 4PL on a dual ESC MOA as well as a couple of other rigs. I think I can get him to do some tests on his system. |
01-14-2012, 06:11 PM | #10 |
Well i took out the LiFe battery and put in some new AA's and I still have the same issue. I even pulled the receiver and put it in my crawler that is equipped with a BEC.
01-14-2014, 09:50 PM | #11 |
Newbie Join Date: Dec 2012 Location: Woodlake
Mine does the exact same thing with the R2104gf receiver in my short course truck. Got the same model receiver in my XR10 and have never had the problem. So this makes me believe my receiver in the SC has a problem. Like you, the symptom will occur on the bench without even running the vehicle at all. Ive timed it and it happens at different intervals of time like anywhere from 45 seconds to 2 minutes. Ive had the receiver several months but bought it used, and it just started doing this the other day. Im gonna buy a new receiver and hopefully that will fix my problem.
01-14-2014, 11:36 PM | #12 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
Try rebinding it. Also, does it happen in the same area. Can you make sure you don't have any big electrical equipment near or power wires above you or WIFI, router, cell phones. Maybe call Futaba and ask for some advice.
01-15-2014, 12:34 AM | #13 |
Not to hijack his thread, but since we have the same problem, in my case it does it everywhere, on the pit table at the track, driving on the track, on my workbench in my garage, driving around in my driveway, just everywhere.
01-15-2014, 05:54 PM | #14 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
are the antenna on the RX being shortened? is the antenna on the Tx in good shape? |
4PL losing signal - Similar Threads | ||||
Losing Bind | XDR | Axial Wraith | 2 | 09-16-2011 04:19 PM |
2/3A cells, Losing out? | bud212002 | Axial AX-10 Scorpion | 11 | 10-21-2009 12:15 AM |
losing power............. | bob1961 | Electronics | 2 | 07-24-2009 10:33 PM |
Losing my mind | Sketch22 | Newbie General | 2 | 02-25-2009 04:58 AM |
Losing virginity | Tronk | Chit Chat | 14 | 02-11-2007 10:16 PM |
