01-17-2012, 11:09 AM | #21 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
| Re: Sensored MMP Stuttering Badly. Ideas?
- Voltage on the battery was at 3.9 v/cell. I put in a new one, but no real improvement. - Re-seated the sensor wire and tried a second wire, no change. - Verified correct wire order. - Tried w/ sensor wire removed and it acted differently....like an unsensored setup would react. - I tried the old firmware (1.26), but no change. - I set the software to the LOW Start Power, but no change. I hope to get another video soon showing my trigger and motor simultaneously. |
01-17-2012, 11:16 AM | #22 |
Rock Crawler Join Date: Nov 2009 Location: poteau
so you have your motor wires hooked up like this. red off motor to red off esc, white off motor to BLACK off esc, and black off motor to WHITE off esc?
01-17-2012, 11:37 AM | #23 | |
| Re: Sensored MMP Stuttering Badly. Ideas? Quote:
Looks like everything is hooked up like it should be. A=red, B=white, & C=black. *shrug* | |
01-17-2012, 11:40 AM | #24 |
| Re: Sensored MMP Stuttering Badly. Ideas? |
01-17-2012, 11:42 AM | #25 |
well, i would guess it's the sensor ring inside the motor then. i'm running the mmp with 18.5t ballistic motor. it runs smooth as glass. i did have trouble getting the sensor wire to plug into the mmp fully. had to use a small pair of needle nose pliers to seat it in fully. on mine the side of the connector with the black wire would not sit down all the way. used the pliers to help push it on. motor/esc looks right, if sensor wire is plugged in fully, it's gotta be the sensor ring. |
01-17-2012, 11:50 AM | #26 | |
Took another quick video to show what's going on. Not sure if it really shows much more than the previous video, but you can see the transmitter throttle position in this one. Be sure to have the volume on. More of the Brushless Motor Stuttering Problem - YouTube | |
01-17-2012, 12:05 PM | #27 |
Quarry Creeper Join Date: Aug 2009 Location: Phoenix
Contact Novak Tech Support. I am not 100% but I think it is your choice of motor/speed control causing the problem. The Novak Crawler motors have something inside them that triggers Novak Crawler Speed controls so they know it's a crawler motor. For example the Goat 3S system and a crawler motor were fine in a crawler application, connect a standard Balistic motor and now the Goat 3S would act like a Kinetic speed control. From Noavk's site: Compatible with Novak's Timbuk2, Goat 2S, Goat 3S and other crawling brushless ESCs The Mamba Micro Pro is not a full on crawler speed control. |
01-17-2012, 12:11 PM | #28 |
the mmp and the novak motors work together. i've been running his same combo for a while now. the deal is the novak motors have a resistor inside them that the novak esc's recognize. with that resistor, the novak esc goes into crawler mode. without the resistor the esc will not go into crawler mode. running a novak motor with any other esc makes no difference. now running a novak esc with another brand motor the esc will not go into crawler mode. |
01-17-2012, 12:15 PM | #29 | |
Also, I'm running a Mamba Max Pro, not a Micro, but I guess neither is exactly a crawler ESC so I'm sure the same rules would apply. | |
01-17-2012, 12:52 PM | #30 |
Pebble Pounder Join Date: Oct 2005 Location: Near D.C. (Centreville)
Be careful installing the sensor wires in the MMP. I have broken 3 input harnesses off the board of the MMP by pushing too hard. It is only held on the circuit board by a very small solder joint. I had this lynching issue and it turned out to be the sensor wire input plug was partially broken off the board of the MMP. Good luck |
01-17-2012, 01:19 PM | #31 |
Rock Stacker Join Date: Nov 2011 Location: NEPA
01-17-2012, 01:33 PM | #32 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
I watched your second video, acts kinda like my LCC setup did. But I ran a Tekin 21.5. I solved it with the esc settings, start power on high, throttle curve stating at 10% (linear). You may need to go to a higher % with the throttle curve, I ran 4s.
01-17-2012, 01:37 PM | #33 |
Quarry Creeper Join Date: Jul 2009 Location: Derby
01-17-2012, 01:42 PM | #34 |
and use the newest firmware
01-17-2012, 02:07 PM | #35 |
| Re: Sensored MMP Stuttering Badly. Ideas? Just tried that, along with the latest firmware, but not help. Tell me this. By "10% linear", what do you mean? I set the throttle curve to "linear" and then set the curve to start at the "10" marker on the horizontal axis. Is this what you meant?
01-17-2012, 03:01 PM | #36 |
yes thats what he means. so the trottle starts at 10%. those novak crawler motors with their 14mm rotors will seem to cogg some at low speeds but it shouldnt be bad as yours in your video. worstcase is the motors sensor board.
01-17-2012, 03:05 PM | #37 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I had a similar issue in my slash 4x4. The BEC was causing some kind of funky feedback. I had to roll the esc firmware back to the first one in the castle link software.
01-17-2012, 05:42 PM | #38 |
Bypassed the BEC and no change there, either. I did speak with Novak about the sensor for the motor. Since I'm not running a Novak ESC, it doesn't really matter which sensor I get (crawler vs. non-crawler). So I placed an order, but I'm sure it won't arrive in time for the weekend. |
01-18-2012, 02:15 PM | #39 |
Seeing that your 3s only has 75% of the power my 4s had try going up to 20% or even 30% throttle curve. You can also try a smaller pinion.
01-18-2012, 02:18 PM | #40 |
The issue lies with your choice of esc and motor combo. are all sensored brushless motors work with any sensored esc? |
Sensored MMP Stuttering Badly. Ideas? - Similar Threads | ||||
Motor stuttering/ cutting out | Armistice | Electronics | 34 | 01-15-2012 05:06 PM |
are all sensored brushless motors work with any sensored esc? | jebster | Electronics | 8 | 01-02-2012 10:47 AM |
MMP & Tekin sensored 13.5 issue | hasbeen | Axial Wraith | 10 | 11-01-2011 07:32 PM |
Sensored Motor and NON Sensored ESC. | Timmahh | Electronics | 7 | 12-11-2008 09:21 PM |
