Thread: fxr question
Old 02-18-2012, 10:48 AM   #1
Default fxr question
ordered a 27 turn handwound HH motor and an FXR for my dingo kit. after i ordered it i read that the FXR is 3s compatable with 35 turn or higher motor but has anyone ran a 27 turn on 3s with one. will it blow up. i guess i could run 2s but i really want to run 3s. thanks
korn_2956 is offline   Reply With Quote
Old 02-18-2012, 10:53 AM   #2
Default Re: fxr question
depending on the kind of load you put through the motor you should be ok. if you were putting this in a 2.2 crawler I would say no (for a couple reasons actually) but if you take care of the system and know what you're doing it wil do fine. If you are rough on your stuff then i would order a 35T, at least as back-up.
JJBTEXAS is offline   Reply With Quote
Old 02-18-2012, 10:59 AM   #3
It will not work, I tryed it, it didn't blow up, it just glitched real bad
You will come up to a rock (small rock) & it wont even crawl it
prusik333 is offline   Reply With Quote
Old 02-18-2012, 12:18 PM   #4
i dont see why it cant handle it. if moa ppl like myself can put 2 hw 35t's on 1 fxr running 3s, why wouldnt it be able to do 1 27t. if u had glitching it may have been from something else.
benoj is offline   Reply With Quote
Old 02-18-2012, 03:59 PM   #5
Ok thanks guys gonna try it and see what happens. I might just have to run 2s till HH has more brxls for sale.
Old 02-18-2012, 04:18 PM   #6
where did you read that? I just checked the specs that came with my FXR and it says you can go as low as 12t on a 2s but nothing about a 35t. maybe im missing it, but ive been running my HH27t with my FXR without issues for months.
crawlhog is offline   Reply With Quote
Old 02-18-2012, 05:09 PM   #7
I saw it on there site. Are you running it on 3s.
Old 02-19-2012, 08:48 AM   #8
sure am, never even thought about the turns but so far so good . ive also been checking the temps and the last run was 30 min. all out and the motor was barely warm. guess im gonna find out.
Old 02-19-2012, 09:30 AM   #9
Moderator Rule Breaker
eric113's Avatar
You shouldn't have problem with 27t motor on 3s. Just watch the temps of both the motor and esc. I would suggest gearing down, will lose little wheelspeed, but will help keep the motor and esc cooler.
I did run 21t 550, fxr with bigger cap on 4s for while.
eric113 is offline   Reply With Quote
Old 02-19-2012, 10:33 AM   #10
Thanks guys gonna do it. It just has to last till I can get a new brxl in March.
Old 02-20-2012, 04:41 AM   #11
Takins website
3S Lipo compatible when used with 35T or higher motor
Tekin - FX Pro Brushed ESC Series
I guess it doesn't say it wont work
I tryed it and it acted funny like the battery was dead (fresh 2S battery) I put my other 35t back in it and it runs great to this day :-/
maybe I'll try it with a newer fxr, the one I tryed it with was one of my original fxr's, from 2009
fxr question - Similar Threads
fxr capacitor question? Goatsniper Electronics 3 10-20-2011 07:47 PM
FXR settings question?? BADASSPONY Electronics 8 03-18-2010 02:39 PM
FXR question Wideopen Electronics 5 03-28-2009 08:24 PM
FXR question Shorty40 Electronics 4 12-08-2008 12:08 PM
Quick FXR Question frdtrkguy Electronics 6 09-26-2008 10:54 AM
