Thread: setting up the esc
Old 02-20-2012, 08:51 PM   #1
Default setting up the esc
I'm new to crawlers and have a question about the castle creations sv2. What should I set everything at and do you have to have your battery hooked up to the esc to program it?
Red_13 is offline   Reply With Quote
Old 02-20-2012, 09:03 PM   #2
Default Re: setting up the esc
That depends on if you are using the Castle Link or not.
If not I wont be much help, I have always used the link.
If you are running LIPOs make sure that your lipo cutoff is set to auto lipo. Obviously you want instant reverse and a decently high drag brake setting. You will have to play around with it a bit and see what works best for you.
SMR 510RR is offline   Reply With Quote
Old 02-20-2012, 09:05 PM   #3
Not sure how it compares to the momba as far a programmability but if it has crawler reverse Id use that. I think that one is geared more for short course racing but not sure I put the momba in everything. You start out with the basic then go to power and so on. It easy. If you have a field programing card you need to have the bat connected but for the pc you don't.
Crawler King69 is offline   Reply With Quote
setting up the esc - Similar Threads
Esc setting question. Beej Axial Wraith 7 01-09-2012 02:46 PM
Setting up a HPI Jolt R esc? TurboShadow Electronics 1 06-20-2011 11:17 PM
sidewinder esc setting yfz350 Axial AX-10 Scorpion 5 02-19-2010 04:24 PM
Which ESC Brake/Reverse Type Setting on my Mamba Max ESC? b00st3d Venom Creeper 3 01-24-2010 04:34 PM
setting up esc CrawlerDan Electronics 2 01-13-2008 02:07 PM
