02-29-2012, 04:14 AM | #1 |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
| FXR problems. Werird glitching
So I have everything hooked up right and I have dual FXR's and the front works just fine.... However when I calibrated the TX & RX to the rear the rear tires started running them stop so it would go with no response from the TX at all. It starts then stops, starts then stops. I am just curious if I just have a bad ESC straight from the box. It syncs up just fine with hot wire. Got all the settings setup and still the same thing happens. Tried the factory reset a few times and still nothing changes. Any Ideas will be more than appreciated Thanks |
02-29-2012, 10:13 AM | #2 |
| Re: FXR problems. Werird glitching
Does it work fine other than starting and stopping by itself? Im guessing that it is just creeping when it starts or is it really spinning? You could try swaping the ESC's front to rear...That will help see if its the ESC or the radio signal that is causing the problems. Also you could open up the dead band in the ESC but that would by my last resort since I like my dead band nice and tight and usually lower it from factory settings. If none of that helps plug a servo into the channel in question and see if that has the twitch. If not then you have a ESC problem, if so then your radio programming is to blame. |
02-29-2012, 10:24 AM | #3 |
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
^^ what he said Another tip I use. Bind and calibrated each esc seperately and on the same rx channel. Then put them in their respective channels |
FXR problems. Werird glitching - Similar Threads | ||||
Tekin FXR glitching!!!! | sniper | Electronics | 65 | 05-02-2013 09:32 PM |
Glitching Problems | YJJPWrangler | Electronics | 5 | 02-19-2011 08:29 AM |
Glitching problems.... | Rocfrog | Electronics | 37 | 05-28-2010 05:50 PM |
Glitching problems | 4ruggy | General Crawlers | 3 | 12-26-2008 09:24 PM |
glitching problems??? | joehein | Electronics | 3 | 02-22-2007 09:35 AM |
