Thread: Mamba Max SCT w/ 1410 3800 sensorless
Old 04-03-2012, 09:28 PM   #1
Default Mamba Max SCT w/ 1410 3800 sensorless
So I bought a Mamba Max SCT kit. It included a 1410 3800 sensorless brushless motor. I didn't realize that it was sensorless when I bought it. I have a two speed Summit trans in a tube Jeep.
The trans is geared really low in the "low" gear. I thought that I could get a bit of speed out of it with a brushless, but it won't crawl for crap.
I still have a brushed motor that I could hook up to it. Before I do that, I wonder what effect gearing it way down will have on the motor and ESC. Will they overheat?
Any help would be appreciated. Thanks. I don't really have the extra coin to just buy a 13.5T Tekin.
Lukefalls is offline   Reply With Quote
Old 04-03-2012, 09:30 PM   #2
Default Re: Mamba Max SCT w/ 1410 3800 sensorless
motor might heat up a little from just high revving for long periods of time, but you could remedy that with a larger pinion, unless you don't plan on running it wide-open most of the time
iamsuperbleeder is offline   Reply With Quote
Old 04-03-2012, 09:52 PM   #3
Thats sort of what I'm looking for. I want a smaller pinion to make it slower. If I can make it crawl at all, it definitely won't be a full throttle very much.
Mamba Max SCT w/ 1410 3800 sensorless - Similar Threads
Bearings for castle 1410 3800 sec1083 Electronics 9 06-08-2012 09:49 PM
Castle Mamba Max Pro SCT HEEELP fmiguel Newbie General 13 05-22-2012 03:36 PM
Mamba max sct esc diggrr11972 Electronics 6 04-03-2012 06:43 PM
