05-11-2012, 02:00 PM | #21 |
| Re: i screwed up novak dig question
Is that a LCC with the MOA conversion?? Interesting. Those sorta look like the Novak Goat (although those, IIRC, used orange clear plastic cases). I would just use them for now and program the GT3B with the dual ESC template. |
05-11-2012, 02:33 PM | #22 |
Quarry Creeper Join Date: Oct 2011 Location: in the 7eventh level of hell
| Re: i screwed up novak dig question so what is so intresting about it? this is how he had it listed - "losi night crawler axles aluminum tie rod. nino chassis stock lnc wheels with rover tires. aluminum ax10 shocks with special caps. 550 1200kv brushless motors tacon dual 35 amp escs fan 5amp 6volt bec metal gear hightorque servo moa brackets blc 48 pitch regears runs great."
05-11-2012, 08:03 PM | #23 |
They are cheap HK ESC's, cant say how well they would work in this build as I doubt they have much of a drag brake. Also throw those motors away, they are complete junk. I bought one to try out and ran it for 10 min and now its in my spare parts bin and it wont come out ever. |
05-11-2012, 09:04 PM | #24 | |
| Re: i screwed up novak dig question Quote:
05-11-2012, 10:36 PM | #25 |
Unsensored brushless motors, they are not smooth at all and made it impossible to crawl. If you have a go fast that needs a decent little motor then throw them in there, otherwise you are better off throwing in a cheap machine wound brushed motor in your crawlers.
05-12-2012, 06:44 AM | #26 | |
1-They eat brushed motors, even good ones. 2-The worm drive acts as the drag brake, so the ESC is not as much of an issue. Set up dual ESC on the hacked GT3B and go run it. If you toast something, then look to upgrade. | |
05-12-2012, 08:30 AM | #27 |
i was wandering about the motors. i have a venom that has a 3000kv tacon on it and it will go where ever i want it to.. i didnt think it would but it has 87spur 15 pinion and i can run a 2s and it will just walk right up any thing. if i put the 3s on it pulls wheelies. that why i thought the motors would be godd for the kids being 1000kv only.
05-12-2012, 08:33 AM | #28 | |
i screwed up novak dig question - Similar Threads | ||||
2x Tekin FX-r with Novak-DIG and DX3R or No dig with FlyskyGT3B | Turbo-s | Axial XR10 | 14 | 02-11-2012 08:16 AM |
Novak The Dig: Dig for Dual Electric Crawler NOV5450 | jmrcardoso | Electronics | 1 | 12-05-2011 04:20 PM |
Motor Question about 18.5 novak,21.5 novak, 18.5 Ballistic | YardFab | Electronics | 3 | 02-26-2010 09:53 AM |
Novak "The Dig" Question | KBrog | Electronics | 7 | 01-31-2010 08:34 PM |
