05-05-2012, 03:16 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: in the 7eventh level of hell
| i screwed up novak dig question
i just realized that the dig i got along time ago is for a two esc set up. i am going to run a mamba max single esc. can i still make this work or am i just phuged.
05-05-2012, 04:23 PM | #2 |
| Re: i screwed up novak dig question
Nope...
05-05-2012, 08:10 PM | #3 |
nope as in no worky?
05-06-2012, 11:49 AM | #4 |
That's correct the Novak dig only works with 2 escs. You need either a punk dig, rc4wd rocker dig, or ones of heyoks digs (vendor here) and one esc Sent from my iPad using Tapatalk |
05-06-2012, 01:04 PM | #5 | |
| Re: i screwed up novak dig question Quote:
It works, but also having proportional makes for a better experiance. For my Futaba 3PM-x, I needed a WantAmix to run dual ESC's later on. Great upgrade. | |
05-06-2012, 07:46 PM | #6 |
I'd buy a second ESC before a punk, you should be able to pick up a used unit cheap. Then when you can get a proper radio you'll have full control.
05-10-2012, 05:50 AM | #7 |
is there something wrong with a novak punk? i would rather run one esc i think. i know with two and my HACKED GT3B tow esc would rock but i just dont really know if i want the weight to advantage issue problem.
05-10-2012, 05:54 AM | #8 |
yeh i bought that novack dig and then finally ran up on an old punk that i was looking for and i eehugh have a novak eeeghg laying around that uughum im not going to be using eeerrrghum anymore. |
05-10-2012, 12:17 PM | #9 | |
Much better control as well if your radio supports it (I'm running dual Sidewinder Micro Pros on 3S to 35T motors in an XR-10. I'm sorry, I have no real clue what the heck you just posted. I believe you had a Novak Dig and then bought a Punk Dig and didn't want the Novak issues?? | |
05-11-2012, 08:08 AM | #10 | |
05-11-2012, 08:39 AM | #11 | |
Since you have a hacked GT3B (like I have for the XR-10), skip ANY KIND OF DIG and get a 2nd ESC. It's easy to program dual ESC's with full front/rear dig as well as front/rear proportional (I like that option!!) Currently I'm running dual CC Sidewinder Micro's on 3S LiPO with 35T motors. The only real change in the "dual ESC template" I did was to change the "steps" for proportional from 20 to 5. I usually run it at 5 or 10 95% of the time except when doing a dig. Last edited by Charlie-III; 05-11-2012 at 11:39 AM. Reason: Fix typos | |
05-11-2012, 09:54 AM | #12 | |
05-11-2012, 11:38 AM | #13 |
| Re: i screwed up Novak dig question
I may be pushing them with 35T's on 3S, your higher wind motors will be easier on them. PS, I have the Sidewinder Micro's in my XR-10, not Micro pro's. The Mamba Micro Pro's will likely do better since they have the heatsink. |
05-11-2012, 11:52 AM | #14 |
havev you ever used Hextronics esc's. i got a crawler from a member and it had dual hex's on it. they any count?
05-11-2012, 12:01 PM | #15 |
the esc has a sticker on it that says car 35 and wiring labels but no name on it. he says they are hextronics 35 amp esc's but i cant find ni info on them.
05-11-2012, 12:38 PM | #16 | ||
If you have them, I would try them. Use the dual ESC template from the 1st page of the "GT3B Hack thread". | ||
05-11-2012, 12:53 PM | #17 |
i thought about trying them. dude had them on a losi each esc was pushing a tacon 550 1200kv brushless motor. like a dipshit i never tried it out cause i bought it to put each esc/motor on seperate crawlers and then part it out what i didnt need. i tested each on after removing them and they ran fine on the bench. let me get a pic of them and i will post them on here so you will at least have a look see.
05-11-2012, 01:04 PM | #18 |
| Re: i screwed up novak dig question |
05-11-2012, 01:04 PM | #19 |
sorry, just noticed it is a car 30 not 35.
05-11-2012, 01:06 PM | #20 |
heres the rig they were on. |
i screwed up novak dig question - Similar Threads | ||||
2x Tekin FX-r with Novak-DIG and DX3R or No dig with FlyskyGT3B | Turbo-s | Axial XR10 | 14 | 02-11-2012 08:16 AM |
Novak The Dig: Dig for Dual Electric Crawler NOV5450 | jmrcardoso | Electronics | 1 | 12-05-2011 04:20 PM |
Motor Question about 18.5 novak,21.5 novak, 18.5 Ballistic | YardFab | Electronics | 3 | 02-26-2010 09:53 AM |
Novak "The Dig" Question | KBrog | Electronics | 7 | 01-31-2010 08:34 PM |
