06-18-2012, 01:05 PM | #21 |
| Re: Brushless ESC recommendation needed
Basically, with my Castle ESC's you set drag brake to what you like (50% in my Wraith, 213% in my XR10) and then set forward/reverse mode to be instant reverse mode. So, if you pull forward it goes forward, let off to neutral and it hits the brakes at 50%, then if you go reverse it hits reverse right away. In the standard mode, you get forward when you pull the trigger, drag brake in neutral, brakes on first reverse push, then back to neutral, and reverse again for reverse. When I played with the BH ESC I had drag brake turned off by accident and it would go forward when I pulled trigger, nothing in neutral, brake when I hit reverse, then while still holding reverse it would start turning in reverse. Basically, I think the circuit wants to see 0 speed before it reverses to save the controller. I'll play around a bit more when I get my other receiver installed. |
06-18-2012, 01:07 PM | #22 | |
| Re: Brushless ESC recommendation needed Quote:
1-Regular brake. When in forward and you move the throttle trigger to "brake/reverse", the vehicle will stop. Hit the brake/reverse on the trigger again, you will get reverse (also called "double pump" brake). 2-"Race brake", no reverse regardless of how many times you hit reverse. Used in some race classes. 3-Crawler brake/instant reverse. When you are going forward and hit the trigger to reverse, the ESC immediately goes into reverse. This is the mode crawlers want. This can be hard on gas powered rigs, thus the "regular brake" mode. ik632 was adding some additional info regarding brake amount setting. | |
06-19-2012, 12:37 AM | #23 |
Newbie Join Date: Jun 2012 Location: oregon city
You cant go wrong with the castle mmp. Its around $110. But worth every penny. You can run sensored sensorless or brushed motors and up to 6s lipo. Its all the Esc you'll ever need.
06-19-2012, 11:56 PM | #24 |
Rock Crawler Join Date: May 2012 Location: Upland
Tekin RS /thread /wallet |
08-09-2012, 01:10 AM | #25 | |
Rock Crawler Join Date: Jan 2008 Location: NORWAY
Just curious,witch other motors will this Speed Passion sensor board/endbell possibly fit ? | |
08-09-2012, 02:31 AM | #26 |
Rock Stacker Join Date: Aug 2011 Location: Canada
The sensor board is integrated into the endbell, so likely it will work on any motor that the endbell will fit on. I tried it on an EZrun 5.5T and it worked. If you've got a motor that bolts from endbell to endbell with three screws, in the same pattern, it might work. It might not too though, I can't really say for sure; could be for 2 pole motors only as I don't know if 4 poles require a different sensor layout. Here's the motor for you to look at Speed Passion | Crawler Master-L Motor Or on ebay for a cheap price Speed Passion Crawler Master-L Motor BIG SALES US23.99 | eBay |
08-09-2012, 02:37 AM | #27 | |
I have ordered the cheap one from ebay,and it would be nice to use that endbell on a shorter motor with a bit more kv | |
08-09-2012, 07:58 PM | #28 | |
08-10-2012, 01:19 PM | #29 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
I got one free with a venom rig I bought. I can push a igloo cube cooler across a concrete parking lot So it has grunt. |
08-10-2012, 02:30 PM | #30 |
Do you think you can gear it up enough to go relatively fast too? I know it's only 1000kv but I haven't run it like that. I wonder how hot it would get geared up in a Wraith.
Brushless ESC recommendation needed - Similar Threads | ||||
Brushless motor recommendation | arrglarks | Electronics | 4 | 06-19-2012 12:40 AM |
Help needed with ESC recommendation. | Andre N | Electronics | 7 | 03-02-2012 01:34 AM |
Took Kit Recommendation Wanted/Needed | getoutandplay | Losi Mini-Rock Crawler | 3 | 11-29-2008 08:04 AM |
ESC Brushless BEST one also lipo cutoff help needed | 4x4Crawler4LIFE | Newbie General | 20 | 02-26-2008 09:01 AM |
