06-27-2012, 11:00 AM | #1 |
I joined the Band! Join Date: Aug 2009 Location: Maryville, Tn
| servo glitching with bec?? wtf!!!!!!
ok well i got a jr z9000t servo used from a guy on here and i went and got a cc bec. followed the diagrams on here and i the only way i can get my servo to stop glitching is to plug it directly into the rx.....im running the axial ae-2 esc....tried ground to bec and ground to rx with same results....please help......( the servo just rotates changing direction constantly
06-27-2012, 11:13 AM | #2 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: servo glitching with bec?? wtf!!!!!!
did you see this? posted right below yours... maybe it will help.. i too am getting an ae-2 and will order a bec.. so following... Wiring Help\Question ESC,RX,Servo,BEC |
06-27-2012, 11:37 AM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Did you remove the red wire from the ESC to the receiver?
06-27-2012, 11:47 AM | #4 |
yeah i did all of that and triple checked....so i am seeing here that it only seems to pitch these glitching fits when i let the radio bounce back to center or hit full lock fast...if you take it slow turning whe wheel it does not glitch
06-27-2012, 11:49 AM | #5 |
| Re: servo glitching with bec?? wtf!!!!!! |
06-27-2012, 11:50 AM | #6 |
maybe the stock radio just cant control the speed of the new servo??? im as lost as a fart in a wirlwind........
06-27-2012, 12:36 PM | #7 |
Pebble Pounder Join Date: Feb 2012 Location: wooster
BEC have the correct/most recent firmware? Programmed with a voltage thats within the servo specs?
06-27-2012, 01:02 PM | #8 |
| Re: servo glitching with bec?? wtf!!!!!! Radio system is too slow for the Digital Servo.
06-27-2012, 01:29 PM | #9 |
yes bec is set at 6 volts.....i think like binary said i need a new rx tx combo...gay...................................
servo glitching with bec?? wtf!!!!!! - Similar Threads | ||||
Glitching or need a BEC? | Pgambardella | Axial SCX-10 | 3 | 03-22-2012 07:43 PM |
Wiring BEC, and glitching MM? | BigJonny | Electronics | 13 | 04-23-2011 12:54 PM |
castle bec causing glitching? | marvinbeaverdip | Electronics | 7 | 01-28-2011 09:54 AM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
CC BEC glitching | rcracer11 | Electronics | 0 | 02-14-2009 03:40 PM |
