10-12-2012, 12:42 PM | #1 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
| Hitec 5955tg
I just was given A Hitec 5955tg servo, and when I tested it, it has full travel one direction, but very little the other. Could it be programed like this? If so how can I reset it to factory setting? Thanks for any input.
10-12-2012, 12:52 PM | #2 |
| Re: HiTec 5955tg
Why do you say it has a ton of travel in one direction but not the other? Yes, it may have been programmed that way (not sure why), but it can be returned to stock. Fill us in, then we can help some. |
10-12-2012, 01:37 PM | #3 |
| Re: Hitec 5955tg
When it is powered up it has full travel in one direction i.e.(right turn) then when you turn left it has about half the travel. Its not the controller it acts the same with 3 different ones.
10-12-2012, 03:06 PM | #4 |
| Re: HiTec 5955tg
OK, stupid question........ how did you set the servo arm???? It's easy to use an existing set-up but not center it to your situation. That is where I would start. Pick a point and then see how far it travels in each direction, I will guess it goes the same each way. But, the arm is NOT centered giving the impression you see. |
10-12-2012, 03:25 PM | #5 |
| Re: Hitec 5955tg
It's not a question if it travels more one direction,(it does indeed) but a question of is it programed this way and if so how do you set it back to factory. Or maybe it has a stripped gear? will have to pull it apart.
10-12-2012, 10:01 PM | #6 |
Quarry Creeper Join Date: Jan 2009 Location: Lowell Massachusetts
| Re: Hitec 5955tg
I think that servo is a 180, instead of 90 like the rest.
10-23-2012, 05:12 AM | #7 |
Pebble Pounder Join Date: Mar 2010 Location: Orlando
| Re: Hitec 5955tg
I just had the same ting happen to me and i did exactly what Charlie said. I pulled the horn off and put it in the center of the servo travel and all is well.
10-23-2012, 05:46 AM | #8 |
Quarry Creeper Join Date: Aug 2011 Location: Spalding, Lincs, UK
| Re: Hitec 5955tg
I had one like this that someone had programmed for a Nitro throttle and brake set up. I found someone with a Hitec programmer to reset everything for me, all was well after that.
10-23-2012, 07:54 AM | #9 |
| Re: Hitec 5955tg
That servo from the factory is set for 180 degree rotation but lots of people have them programmed to do 90 degrees like a regular servo. Anyway, you'll need someone with a programmer to reset it to default. There's also response time and a few other things you can program.
10-23-2012, 09:41 AM | #10 | |
| Re: Hitec 5955tg Quote:
Hitec 5955tg - Similar Threads | ||||
how is the hs-5955TG | theclimber | Electronics | 11 | 10-07-2011 09:34 PM |
HS-5955TG Question | ForumSn0w | Electronics | 10 | 04-12-2008 05:01 AM |
HS-5955TG issues? | Offroader5 | Electronics | 4 | 01-20-2007 11:29 PM |
Smoked HS-5955TG | DISTURBIN' tha PEACE | Electronics | 10 | 10-07-2005 04:02 AM |
