Thread: faster in reverse than forward
Old 11-07-2012, 05:10 PM   #1
Default faster in reverse than forward
I just installed a traxxas xl5 esc in my scx10 and it seems to faster in reverse than forward. Is this something that can be changed?
if it matters, i'm using a spektrum dx3.0 tx/rx
dirtymike is offline   Reply With Quote
Old 11-07-2012, 11:45 PM   #2
AddictedtoRC1's Avatar
Default Re: faster in reverse than forward
Try re calibrating the radio with the ESC.
AddictedtoRC1 is offline   Reply With Quote
Old 11-08-2012, 12:04 AM   #3
what motor are you running? some have advanced timing to run faster one way.
First, check the motor wires are connected the right way, then recalibrate the ESC radio. You may find you have to reverse the throttle direction to get it going in the right direction, if so then recalibrate again after you've flicked the switch.
Also, check the end point adjustments on your radio if it has them, you may find one has been turned down more than the other.
Tonysmini is offline   Reply With Quote
Old 11-08-2012, 08:55 AM   #4
ill try the calibrating. Right now i've got the stock axial 27t in it, but I also have a 55t integy for it
Old 11-08-2012, 08:56 AM   #5
swap the wires on the motor!
Sent from my SCH-I500 using Tapatalk 2
RKSTAR is offline   Reply With Quote
Old 11-08-2012, 10:18 AM   #6
Then make sure you invert your throttle
BC-Brian is offline   Reply With Quote
Old 11-08-2012, 11:13 AM   #7
Did you make sure your transmitter was set to zero on both the forward and rev. for the throttle channel? I have mine set to be 100% for the forward operation but only 40%(limiting the rev. speeds) in Reverese. then trouble shoot with motor wires etc.
Just where I would start.
Mikel1871 is offline   Reply With Quote
Old 11-08-2012, 11:24 AM   #8
Im having the same problem. Stock Axial SCX10 with 1.9, homemade wheel weights, traxxas xl5 esc and 35t RC4WD motor with 2s lipo. Mine seems to go faster in Reverse than forward. The Esc has been calibrated with sport mode. And ive run out of ideas of what it could be. ALso using the stock axial remote and receiver. ALso when I was taking out the receiver out of the box the bottom broke off with it. I know being a newbie yes you can say DUMBA$$. Would that have anything to do with that cutting in and out?? I also noticed Hesitation as well.
OGMUDBONE is offline   Reply With Quote
Old 11-09-2012, 07:31 PM   #9
I agree. you guys have your motor wired backwards. switch that and reverse the radio
tunnalram is offline   Reply With Quote
Old 11-09-2012, 07:38 PM   #10
Yep did the same thing the other day just switch the moter leads and rev. the tx
TrickyRicky is offline   Reply With Quote
faster in reverse than forward - Similar Threads
Fast Forward, Faster Reverse dAng! XJ Axial Wraith 17 01-13-2012 08:20 PM
reverse is faster than forward wassaakk Newbie General 6 07-01-2010 07:22 PM
Is it really faster in reverse? RickM Axial AX-10 Scorpion 3 02-10-2010 10:07 PM
WK runs faster in Reverse than Forward? HUH?! JavelinSST390 HPI Wheely King 7 08-31-2007 07:14 AM
