04-02-2013, 08:50 PM | #41 |
Newbie Join Date: Jul 2012 Location: Pearland
| Re: Tekin Pro4 vs. Roc 412
I'm surprised no one mentions that the Roc412 is 4S capable while the Pro4 is only rated to 3S according to Tekin's site. Seems to me that the Roc412 is the better option, it has a lower kv which is better for crawling, and if you want to go stupid fast, throw in a 4S pack and you should get a better top speed versus a Pro4 on 3s.....am I missing something here?
04-03-2013, 07:25 AM | #42 |
The reason they're rated differently is the intended use. With (near) constant high speed, as the Pro4 is a racing motor, 3S will produce enough heat. Crawling with very short bursts of full power the motor doesn't generate as much heat, so a higher voltage can be applied. Crawling with a Pro4 on 4S is just fine while racing with an ROC412 on 4S will cause overheating! |
10-27-2013, 08:37 PM | #43 |
Newbie Join Date: Jul 2010 Location: sedgwick
I would go 550 sc4x 7.5t it's got more control and torque than the crawlers need. Use a smaller pinion if u are scared of going fast with it. I have a 6.5t in a slash 4x4 and with a 20t pinion can go as slow as I want with it so in a crawler with say a 15t pinion u will be fine.
10-28-2013, 04:35 PM | #44 |
I also just put this into a night crawler with a modded stock pinion, way faster just as much power and is on a sv3 so a mmp would help it out more but it's pretty good without it.
04-24-2014, 03:36 PM | #45 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
Taking this topic to the top instead of making a new. I simply cant decide between a Pro4 and ROC 412 for my Wraith. I intentially thought about the ROC 2300kv but after reading some threads many that tried both seem to prefer the Pro4 even for crawling. I'm mainly in to crawling and trailing, but do want some wicked torque and wheel speed to "foff" past my budies up the hills, throw massive amounts of dirt and mud, thear up terrain. Hopefully it's possible to combine. Running 35t/3S and feels it oacks power under certain situatilns and the wheel speed is not enough. |
04-24-2014, 06:07 PM | #46 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Tekin Pro4 vs. Roc 412 Quote:
I base my findings from manufacturers not the interweb hear-say....... Just sayin Last edited by JokersWild; 04-24-2014 at 06:10 PM. | |
04-25-2014, 09:19 AM | #47 |
Moderator Join Date: Jan 2004 Location: chicago
i got the pro4 3300 in 4 of my rigs, 2 of them wraiths, and i think its a fantastic all-around motor, especially if you want to have some wheelspeed on reserve.
04-25-2014, 11:57 PM | #48 |
Quarry Creeper Join Date: May 2012 Location: vernon bc
I dont want to call them down but I have lost two roc motors due 4o the magnets breaking loose. Not sure why its happening but 200.00 a motor starts to hurt the pocket book.
04-26-2014, 12:20 AM | #49 |
| Re: Tekin Pro4 vs. Roc 412 Stop putting 4s into a motor designed for 3s and you'll keep from breaking the rotor magnets. |
04-26-2014, 12:25 AM | #50 | |
04-26-2014, 03:31 AM | #51 | |
05-04-2014, 09:14 AM | #52 | |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
Sent from my SGH-T889 using Tapatalk | |
Tekin Pro4 vs. Roc 412 - Similar Threads | ||||
World release, Tekin ROC 412 | jetboat | Electronics | 431 | 03-19-2014 03:25 PM |
TEKIN Christmas Giveaway! - ROC 412 Crawler Motors | Ty@Tekin | Electronics | 598 | 10-21-2013 07:30 AM |
Christmas Sweetness - Tekin Roc 412 | GrimJeeper91 | Team Losi Comp Crawler | 6 | 01-01-2013 05:47 PM |
Tekin ROC 412 motors in stock! | RPP Hobby | RPP Hobby | 0 | 12-24-2012 10:48 PM |
Tekin ROC 412????? | Soulo747 | Electronics | 1 | 12-09-2012 05:18 PM |
