02-18-2013, 09:18 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: Hayden
| Hitec 7950th going crazy..
I purchased a hitec 7950th and bec became after reading that was the best bet for crawling. Wired it up and made about 3 hours worth of runs today, performed really well... Got home threw a fresh battery on it and drove it around in the house. Later I took my shocks of cause the rod ends were lose... After putting them back together, I turned it back on and the servo went ballistic. Jerking back and forth, non responsive to trim or transmitter. And getting hot really quick... I unplugged my battery and waited a few minutes and it did it again... Anyone ever experienced this. Any help is greatly appreciated....
02-18-2013, 09:27 PM | #2 | |
Pebble Pounder Join Date: Aug 2012 Location: bonney lake
02-18-2013, 09:48 PM | #3 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
| Re: Hitec 7950th going crazy..
I had a 7954 do something similar after a couple months of use. Hitec ended up replacing the board. Can't say if this is the same thing but if the rest of the electronics check out it maybe time to send it in.
02-18-2013, 09:59 PM | #4 |
| Funny you should say that... I let everything cool down and then started troubleshooting. The bec gets pretty warm and the servo is non responsive. No glitching nothing. So I started tapping on the bec and ever so often the servo will go crazy. Tap it again and it stops. I am running castle creations 10 amp bec and tekin fxr ESC.
02-18-2013, 10:06 PM | #5 |
Quarry Creeper Join Date: Apr 2012 Location: Missouri
Try it without the bec.
02-18-2013, 10:06 PM | #6 |
So would y'all say its the bec causing problems.... I am new to bec's. I have always had rtr's. I hope its not the servo. I killed my budget getting it and the esc/motor combo. Became would be alot friendlier to the wallet..
02-18-2013, 10:26 PM | #7 |
02-18-2013, 11:07 PM | #8 |
02-19-2013, 07:18 PM | #9 |
Well today I decided to take the shrink wrap of the bec and see if anything look weird. Well it did. The whole board was covered in corrosion. I took a fine metal detail brush and scrubbed the corrosion away for a few minutes and now it works flawless...
02-19-2013, 08:43 PM | #10 |
That's crazy how long have you had the became for?
02-19-2013, 09:00 PM | #11 |
Got it brand new in the mail from ckrccrawlers.com on Friday.. I don't thinking was there fault. Prolly been sitting around for a while....
02-19-2013, 09:54 PM | #12 |
| See that's what's crazy is my buddy just got one the other day too hooked it up for him and the jk was waggin like a dog wanting a treat... and it was brand new from the lhs
02-19-2013, 10:39 PM | #13 |
Well is said it was working fine. BEC got hot and servo stopped... Off to buy a new one tomorrow..... This sucks....
02-20-2013, 12:39 PM | #14 |
Went to lhs today and had them test everything to double check. Well servo is fried.... Bummer. But on the bright side, contacted Hitec and they are sending a free replacement... Great customer service... So far....
02-21-2013, 04:00 PM | #15 |
Rock Stacker Join Date: Dec 2010 Location: manchester
what kind of battery are you running? only reason I ask is according to hitec, that servo should be good on 2s? just curious for my own knowledge as I am running the same servo. here is hitecs description. so what I gather from this is you don't need a bec if running 2s? not sure though. This is the Hitec HS-7950TH High-Voltage Mega Torque Digital Servo. This is the most powerful servo Hitec has produced to date. The "Ultra Torque" HS-7950TH is designed to operate on a two cell LiPo Pack! Featuring Hitec's high resolution "G2" second generation programmable digital circuit and their indestructible Titanium gears, the HS-7950TH has the performance and durability you've come to expect from a Hitec servo. Other features in the HS-7050TH include a 7.4v optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing. The HS-7950TG has been designed for the most demanding hobby applications including the largest aircraft and monster trucks. Featuring a titanic 403oz./in. of torque at 6.0 volts, while still maintaining a respectable 0.15 second transit time Last edited by 1natehundred; 02-21-2013 at 04:05 PM. |
02-26-2013, 12:27 PM | #16 |
I am running a 3s lipo with a castle creations bec set at 7.4v... I have heard you need the became because the amperage pull will fry the internal became on most speed controllers..
03-10-2013, 09:14 PM | #17 |
Newbie Join Date: Feb 2013 Location: Fargo
Great information! New to crawling and I just picked up a 7950 and will try without my BEC.
03-10-2013, 09:22 PM | #18 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: Hitec 7950th going crazy.. |
03-10-2013, 09:49 PM | #19 | |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: Hitec 7950th going crazy.. Quote:
Your ECS internal BEC would not like it and will glitch the hell of it. Running any Hitec 7955, 7954, 7950, 7980...etc without external BEC is like running a big block V8 with a lawn mower fuel pump. Its not going to work. Testing on the bench, yes, but actually running it, no. | |
03-11-2013, 03:56 AM | #20 |
i used to have a bec in my scaler and after burning 2 servo i found that the bec stopped working and letting all 3s voltage through. so do check them and water proof them if you use it on a scaler.
Hitec 7950th going crazy.. - Similar Threads | ||||
Hitec 7950th | Wasp26Jim | Electronics | 3 | 02-22-2011 07:34 AM |
hitec hs-7950th on 3s | dusty sweep | Electronics | 5 | 10-19-2010 03:14 AM |
Anyone using a hitec hs-7950TH??? | yzf128r | Electronics | 13 | 02-26-2010 04:28 PM |
