05-06-2013, 04:39 PM | #1 |
Quarry Creeper Join Date: Feb 2011 Location: USA
| ESC throttle problem
ok so i just set all the elctronics up on my jk, I got mamba Max Pro, and brushless motor 5700 its a bit too fast but i toned it down a little bit, no the problem is that every time i hit the throttle for a slow start the truck jumps off then goes slow and thats gonna suck for crawling cusz its seems everytime somthing gets in the way it jumps off, 2nd problem everytime i shut the transmitter off the car goes in reverse??? HELP |
05-06-2013, 04:44 PM | #2 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
| Re: ESC throttle problem
you may need to recalibrate your transmitter to the esc if you haven't already..?.. also you shouldn't ever turn the radio off first..turn the truck off then your radio..i think you can set the failsafe mode also, so it's in nuetral or full brakes are applied..maybe check the manual for that
05-06-2013, 04:55 PM | #3 | |
| Re: ESC throttle problem Quote:
05-06-2013, 05:28 PM | #4 | |
05-06-2013, 06:04 PM | #5 |
Do u have the castle link and software on your pc? You may need to go in and reset the esc to default settings. Was the esc new or used? -sent from my smarter than me phone |
05-06-2013, 10:16 PM | #6 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
Brushless, is it sensored? It sounds like it is not cause that "jumping" is coging. Also that is a very high kv motor even for a trail truck. Getting a lower kv/sensored motor will fix the problem. Sent from my GT-I9100 using Tapatalk 2 |
05-07-2013, 01:47 AM | #7 | |
the 2nd one i have the throttle steady and just holding the truck back its like a mad dog. i also have castle creation in field card. i know the kv is too high, i got mamba max pro with 3s lipo 5000, i need a slow motor with high torque, what would be good with my esc and 3s lipo? Last edited by moedawi; 05-07-2013 at 01:50 AM. | |
05-07-2013, 02:14 AM | #8 |
Just bought Novak Ballistic Crawler Brushless Motor 18.5T, hopefully it fixes the problem...
05-07-2013, 03:57 PM | #9 |
Sorry I do not see your videos. Might be my phone :( That motor should fix it :thumbup: Sent from my GT-I9100 using Tapatalk 2 |
05-08-2013, 09:03 AM | #10 |
Quarry Creeper Join Date: Jan 2009 Location: B-E-A-utiful Vancouver Island
castle brushless products are uncensored(lots of coging/jumping at low speed)..... not designed for low speed crawling, more designed for high speed bashing/racing. if your going brushless in a crawler you need to get a censored motor and ESC.
05-09-2013, 11:06 AM | #11 | |
The ESC is mamba max pro censored as well. let me know plz | |
05-09-2013, 11:18 AM | #12 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
I had run a 18.5 Novak in my sportsman rig and then in one of my trail rigs and it worked really good. |
05-09-2013, 11:34 AM | #13 |
Sounds like you need to get into the ESC programing with a castle link and do a little fine tuning. As for the ballistic motor, I don't have any experience with them, but maybe play with the gearing a bit to see if that helps as well. Make sure you only change one thing at a time before testing, that way you will know what helps and what hurts
ESC throttle problem - Similar Threads | ||||
esc problem no throttle control | mud_life_19 | Electronics | 1 | 11-08-2012 09:41 PM |
throttle and turn problem | mudn_1 | Electronics | 3 | 12-01-2010 06:23 PM |
having problem with throttle? | lildjloop | Axial AX-10 Scorpion | 17 | 04-28-2009 02:22 PM |
throttle problem | octigonwallrus | Electronics | 5 | 09-10-2006 12:56 PM |
