Thread: picking the right radio
Old 02-26-2014, 03:05 PM   #1
Default picking the right radio
looking to upgrade my radio. Want to add four wheel steering. I want to be able to steer rear separate from front. I will at a later date also add a dig system maybe double digs. Might add a winch . my ride is a gmade r1 rock buggy. looking for a radio that will grow with me so I don't have to buy another in the future. Would a stick radio be better. I would prefer to stay with a pistol grip. Any suggestion's would help.
Rockwolf58 is offline   Reply With Quote
Old 02-26-2014, 03:31 PM   #2
Default Re: picking the right radio
I would look at:
Futaba 4PLS -- They are really nice radios and support mixing for steering and dual esc for MOA. They pretty much do everything but it lists for around $250.
Hacked GT3B or GT3C from Overkill RC -- The radio firmware has been upgraded to support up to 8 channels and supports mixing. Depending on model/options you can get it for under $100. Flysky GT3B
I have both radios and like both of them. I would be hard pressed to pick, if I had to pick just one.
k7zpj is offline   Reply With Quote
Old 02-26-2014, 03:43 PM   #3
would the futaba 4pls also support at least one dig unit
Old 02-26-2014, 04:18 PM   #4
spend the money on a good 4pls or 4pks. i went cheap with a rc4wd 4 channel and regret it know that i need more channels great radio just should have spent the money on the two mentioned radios. this is just my two cents.
mark32 is offline   Reply With Quote
Old 02-27-2014, 10:28 AM   #5
I love my dx3r and dx4s.
Master Basher is offline   Reply With Quote
Old 02-27-2014, 10:35 AM   #6
GT3b or GT3c. Fully hacked from overkillrc.com. With everything you want to do I am counting 6ch needed, there is no other pistol grip radio out there that will do what you need.
I have a 4pl and it's for racing. I use my Gt3b for all my crawling stuff. 4ws/2-speed trans/dual winch/dig, the hacked flysky does it all.
Exocaged is offline   Reply With Quote
Old 02-27-2014, 02:01 PM   #7
X2, you can now or you will later.
Both are great radios, I knew that I was going to be in the hobby for awhile so I bit the bullet and got the 4pk years ago. Never regretted it, has been able to do whatever I needed it to from go-fasts, to go-slows, to nitro, to whatever.
They are the standard for a reason.
dentonmac is offline   Reply With Quote
Old 02-27-2014, 02:56 PM   #8
The GT3B or GT3C is the only radio choice that gives you enough channels to do what you want to do.
picking the right radio - Similar Threads
Need help picking a lathe Fatboy Tools, and Procedures 3 01-21-2013 02:42 PM
I need some help picking out my electronics... Benjamin Electronics 5 01-18-2013 11:00 AM
Help picking a new radio set. Paul1234 Electronics 2 12-06-2011 06:39 AM
Help picking which radio system to get. Paul1234 Axial AX-10 Scorpion 8 08-22-2011 12:10 PM
Picking a radio?? Rocfrog Electronics 7 12-04-2006 08:47 PM
