07-08-2013, 09:05 PM | #1 |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
| screw stuck in servo... So I got a hitec 645 servo in a trade but when I tried to remove the servo arm I found that the screw was stripped. I drilled out the screw head and removed the servo arm but the rest of the screw is still stuck in the servo. Anyone have any ideas how to remove it? I can't get a good grasp on it with a set of needle nose pliers. I also can't weld so I can't weld anything to it to be able to get it out... |
07-08-2013, 10:49 PM | #2 |
Rock Crawler Join Date: Aug 2011 Location: dallas
| Re: screw stuck in servo...
Ive got the same issue w a 645 but I havent tried drillin it yet.
07-09-2013, 04:55 AM | #3 |
Good hardware store or McMaster-Carr would have left hand drill bits. A 1/16th" bit would likely work.
07-09-2013, 05:53 AM | #4 |
Something that has worked for me before is to grip the remaining part of the screw with side cutters. If there is a little bit of screw sticking up, you might be able to use the side cutters like a small pair of pliers. The usual disclaimer of be careful and wear eye protection and proceed at your own risk etc. Opening of side cutter < === remaining part of screw Have the screw pointing up and down, approach the screw from the top with the side cutter opening like an upside down V. Carefully apply pressure with the blades of the side cutters so that it grips opposite sides of the screw. Because the metal of the side cutter will be quite hard, it will often be able to dig itself into the softer metal of the screw. Now gently rotate to remove the screw. Good luck! |
07-09-2013, 07:28 AM | #5 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
First you can always buy new gear...... And other is you can drill and tap larger to 3 mm
07-10-2013, 10:44 AM | #6 |
Quarry Creeper Join Date: Aug 2009 Location: Gamecock Country
Get a dremel with the cutoff wheel and cut a slot in the center across the screw head and remove it with a flathead screwdriver. Done this many times. Very easy.
07-10-2013, 12:50 PM | #7 |
Rock Crawler Join Date: Jul 2011 Location: USA
how much of the screw is sticking out? if there is a little try notching it with a cutoff wheel like it was said above me. if not you might have to try and drill it out, probably not easy without screwing up the servo gear. worse case you might have to buy a new top gear for the servo, but on a hitec 645 it might not even be worth it. |
07-10-2013, 01:32 PM | #8 |
| Re: screw stuck in servo... |
07-11-2013, 09:59 AM | #9 |
You don't need to use the cutoff wheel to make the slot so deep it hits the servo's splines. You can make a slot plenty deep enough to use a flathead. I have never seen a screw in a servo too small to slot. Worse case is that you're out 1 screw.
screw stuck in servo... - Similar Threads | ||||
Stuck set screw and hex key broke in it! | RickM | Tools, and Procedures | 11 | 08-19-2011 12:34 AM |
How to remove a screw that is stuck in a Bruiser frame because of Thread lock? | utieh | General Scale Talk | 10 | 04-23-2010 06:35 AM |
Servo Stuck | Ramination | Newbie General | 2 | 03-05-2010 08:21 PM |
pinion gear screw stuck | philtSF505 | Newbie General | 15 | 01-20-2010 07:19 AM |
Hitec Servo (screw) | Harvo | Newbie General | 16 | 01-24-2009 07:44 AM |
