08-03-2013, 03:05 PM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: roy
| Burning up lipos
I have a tekin rs esc hooked up to a reedy 17.5 and running a hh1000 2s 35c lipo. The lipo and motor are getting hot immediately. I have a cc bec hooked up to the reciever and the red wire pulled on the esc going into the reciever. Any suggestions
08-03-2013, 03:16 PM | #2 |
| Re: Burning up lipos
Which trans/axles? Whats the spur/pinion gearing?
08-03-2013, 03:17 PM | #3 |
Pic of the setup
08-03-2013, 03:42 PM | #4 |
I plan on doing 87/ 14 but this is just bench testing. No tranny hooked up or nothing just as you see in the pic
08-03-2013, 05:25 PM | #5 |
Rock Crawler Join Date: May 2012 Location: Upland
Are you sure that motor doesn't need new bearings? It looks beat. Also, are you running any timing, boost, or turbo in the esc? That output of that battery is small. It may not be providing enough power. Does the bec get hot, too? Sent from my PG86100 using Tapatalk 2 |
08-03-2013, 06:16 PM | #6 |
This is the setup I pulled out of my b4. I was running stock so no boost and no timing. The only thing I added was the bec because I was going to run it in my wraith
08-03-2013, 06:17 PM | #7 |
Bec does not heat up. Will try a bigger lipo
08-03-2013, 06:51 PM | #8 |
Quarry Creeper Join Date: Aug 2007 Location: Bowling Green KY
Seems it would be a motor issue, more than likely bearing. Umm that's a Novak motor in the pic not a Reedy.
08-03-2013, 07:31 PM | #9 |
Yes it is a novak. The reedy was getting to hot to keep testing. Was going to try a 1300 3s or should I just stick with my buggy setup and run a 5000 2s
08-03-2013, 07:52 PM | #10 |
So it's running hot on both motors? I've run Novak and Reedy never had any issues and I run 2&3s 2200 li-po with 25-30c. I've not had luck with Tekin... I've burned up 2 FX-R's. so only thing I can think is hook your RS up to a hot wire and reset.
08-03-2013, 07:57 PM | #11 |
Excellent advice will hook it up tothe hotwire and reset
08-03-2013, 08:00 PM | #12 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Might be a good idea to add some shrink wrap to that deans plug....... And Roy where? |
08-03-2013, 08:46 PM | #13 |
Just bench testing to make sure everything works before putting into the wraith. Having issues updating the hotwire. Trying to follow tekins instructions. In the rock fields of Roy |
08-03-2013, 11:32 PM | #14 |
What battery did you run in the b4? The amperage and the c rating determines how much power the battery is able to supply. 1Ah at 30c "should" supply 30 amps. That rs will be trying to deliver many more amps than that and will heat up trying to do so. Sent from my PG86100 using Tapatalk 2 |
08-04-2013, 08:35 PM | #15 | |
| Re: Burning up lipos Quote:
Burning up lipos - Similar Threads | ||||
Burning up MOtors HELP | Pegasix | Electronics | 21 | 05-19-2012 04:19 PM |
Keep Burning Motors | Playa92687 | Electronics | 4 | 05-08-2012 04:48 PM |
why am i burning up motors?? | hoghead5150 | Axial Wraith | 52 | 11-08-2011 07:19 PM |
MMP burning up??? | Erock | Electronics | 4 | 07-17-2011 08:58 PM |
Please help burning servos | ax10tattooman | Electronics | 12 | 09-10-2010 02:16 PM |
