08-24-2013, 07:40 AM | #1 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
| tekin rs only has 50% power in reverse
Ok I've tired resetting everything and still only get 50% throttle in reverse . Forward seems fine. I'm running a Novak 35T terra claw . Thought I'd ask here first before calling the help line. I'm using a FlySky FS-GT3B and during set up I noticed it won't run with the throttle/brake in normal setting and has to be in reverse surely the radio is not my problem. I have a new motor on the way.
08-24-2013, 07:49 AM | #2 |
| Re: tekin rs only has 50% power in reverse
What settings are you using in the esc? Did you calibrate the esc/radio?
08-24-2013, 07:51 AM | #3 |
| Re: Tekin rs only has 50% power in reverse |
08-24-2013, 07:56 AM | #4 |
Are you setting the RS with a hotwire or manually(with the buttons an LEDs as a guide)? I had that issue with my sons with the RS an a 13.5t redline.. but it was 50% forward.. I had to manually reset the esc to start with to get it working then once I got it on the hotwire it was fine tuned. I Aldo found that I had to bind the rx to a diff channel on the tx.. I was having issue with the throttle not catching till it was half way pulled.. just a thought.. |
08-24-2013, 08:46 AM | #5 |
I do not have the hotwire pc interface so all I can do is use the quicktune adjustments thru the LED. I do not think I can change the mode without the hotwire set up. it says in the manual that the hotwire pc interface is needed for custom settings.
08-24-2013, 08:48 AM | #6 |
Is the hotwire a must have item at $39 shekels?
08-24-2013, 08:55 AM | #7 |
I run half a dozen fxr's an a couple RS's.. the hotwire is a must.. If you can find a friend with one or a lhs that has one, that's the way to go. As it only needs setup once.. but its great to have, cause my friends use mine an we don't have a lhs... |
08-24-2013, 09:00 AM | #8 |
| Re: tekin rs only has 50% power in reverse |
08-27-2013, 03:28 PM | #9 |
After I installed my HH motor I see the issue was in the motor, not the ESC cause the HH motor seems to have full throttle in reverse now. Novak is that Viking for problematic?
tekin rs only has 50% power in reverse - Similar Threads | ||||
Little power in reverse | nuckle | Electronics | 2 | 02-28-2013 08:28 AM |
Reverse power | klausdenmark | Newbie General | 2 | 06-22-2012 04:21 PM |
Is the Tekin B1R "low power in reverse" issue fixed? | GWEEDZ | Electronics | 3 | 05-27-2011 12:50 PM |
EVX (3014) has more power in reverse | Brawler | Electronics | 2 | 01-31-2011 08:05 PM |
Reverse Power Problem need help | bulletproofcustoms | Tamiya Clod Buster | 2 | 11-15-2005 05:13 AM |
