Thread: esc/reciver help
Old 09-18-2013, 07:55 PM   #1
Default esc/reciver help
hey guys the other day i was playing with my ax10 in the creek and i got it a lil wet but have my stuff water tight or thought so anyways after a little water play i went to the trails and about 20 min in my car just took off and i had to smash reverse and it stoped but would not go backwards and not there is a flashing red light on the esc
JayHammy is offline   Reply With Quote
Old 09-18-2013, 08:02 PM   #2
Sounds like ya got wet....take it apart....and let everything dry out when it's dry plug every thing in and make sure it works ....if it does pop all the circuit boards out and dip everything in plastidip...you. Never have another problem...same thing happened to me...git the rx wet..ps..out some 3" extensions on the rx before ya dip it
Sent from my PI39100 using Tapatalk
stevetate12 is offline   Reply With Quote
Old 09-18-2013, 08:04 PM   #3
Default Re: esc/reciver help
i plastidiped my esc and reciver and everything worked fine till bout 20 min after i got out the water and there was no water in the reciver box at all aax10 ridcrest is what i have too
Old 09-18-2013, 08:08 PM   #4
how long did you let the plasti dip dry for?
mjc597 is offline   Reply With Quote
Old 09-18-2013, 08:08 PM   #5
day or 2 before i went out and ran it in the wter
Old 09-18-2013, 08:46 PM   #6
Try it with a different rx. If that doesnt help try it with a different esc. You can try putting the electronics in a bowl of rice to dry them out. Btw, conformal coating is the way to go.
Calderwood is offline   Reply With Quote
Old 09-18-2013, 11:38 PM   #7
I plastidipped a sidewinder and receiver. It was ok first couple of times it got wet, but eventually I had problems with it suddenly going into reverse or just not responding to controls at all. The esc eventually burnt out just splashing in a stream. I have epoxied the new esc. but will not drive into deep water now. It's done just in case there is some water around.
M1tch is offline   Reply With Quote
Old 09-19-2013, 03:42 AM   #8
I did a mamba max pro with plasti-dip. It was fine the first couple times it got wet...but it eventually went up In smoke on me...I looked into some conformal coating that was recommended in some threads and used it on some receivers and my wife's tekin fxr....all of them have been good so far..
Old 09-19-2013, 04:24 AM   #9
I've never had a problem with the plasti dip...my guess is there was still a water way into the thing...i use all castle sidewinders.and I dip the ones that aren't sv3's when it dries you have look at it closely the dip shrinks so sometimes there's a little hole that can let water in that ya gotta cover up....
Old 09-21-2013, 06:52 PM   #10
has anyone ever heard of a run on sentence cuz ive heard of them but cant quite figure out what they are if you can help me that would br great cuz im kinda baffled you can just reply to this post cuz ill be watching to see what it is unless i have to work but if not i might be out playing so thank you
jado6006 is offline   Reply With Quote
esc/reciver help - Similar Threads
question about repossitioning the esc/reciver box wmax99 Axial Wraith 6 08-13-2012 07:43 AM
spexktrum dx3r with moped esc,fan, and reciver 279.00 fanto57 Newbie General 1 12-27-2009 02:25 PM
reciver help!!! tonylivestoday Newbie General 6 04-05-2009 10:46 PM
esc or reciver not working smilodon Electronics 5 07-29-2007 09:03 PM
vmg esc/reciver cammok5 Electronics 2 04-26-2007 08:35 PM
