Thread: HiTec 7955 won't quiet down
Old 10-07-2013, 05:07 PM   #1
Default HiTec 7955 won't quiet down
I just installed a HiTec 7955 servo and a CC 10amp BEC. The servo is acting like it can't find zero and is making noise. I've played with the trim adjustments on the transmitter and it doesn't help. There is no noticeable chatter of the steering. I then disconnected the BEC from the receiver,reinstalled the red wire to the ESC to receiver connector and that didn't solve the problem either. I'm running a HH BRXL, a 3 cell lipo, and the Axial receiver. Any ideas?
raceeng18 is offline   Reply With Quote
Old 10-07-2013, 05:40 PM   #2
Default Re: HiTec 7955 won't quiet down
Its a digital servo, perfectly normal behavior, its going to always be trying to find center, If you lift the wheels off the ground it should stop buzzing.
WAFFLE is offline   Reply With Quote
Old 10-07-2013, 05:49 PM   #3
You're right, it does stop making noise when I lift the front end. Thanks WAFFLE. Had me worried for a while.
Old 10-07-2013, 08:08 PM   #4
mmmmmmmmm waffles!!! I love waffles
rockhugger is offline   Reply With Quote
Old 10-07-2013, 08:31 PM   #5
Try a Savox digital if you think the HiTec is noisy.
jaloos is offline   Reply With Quote
Old 10-07-2013, 08:37 PM   #6
X2
I have a couple and they tend to be noisy at times, nothing to worry about
rangercat23 is offline   Reply With Quote
Old 10-07-2013, 08:42 PM   #7
with everything I've read here about digital servo's, I don't remember anyone complaining or even mentioning the noise they make.
Old 10-08-2013, 05:43 PM   #8
I've got two7950s and eight 7954s and they all make the clicking noise sometimes.
xCoolHandLukex is offline   Reply With Quote
HiTec 7955 won't quiet down - Similar Threads
Hitec 7955-TG Servo losi22 Electronics 10 09-02-2012 01:40 PM
Anyone run a Hitec 7955 at 7.4? RickM Electronics 20 09-03-2011 02:02 AM
hitec hs-7955 afrofroggy Electronics 1 01-05-2011 01:03 AM
hitec 7955 Mr.Cool Electronics 3 12-04-2008 05:06 PM
