Thread: 4PLS help
Old 10-07-2013, 10:03 AM   #1
Default 4PLS help
Im new to the sport and just bought the 4 pls for my xr10. The instruction manuel is good for showing what it can do but thats about it. My main question I have is, do I have to connect my esc's (I'm running dual esc's) to the transmitter for it to have the data? or is that even required? They have already been set up from the previous owner of the crawler
1ULOST2 is offline   Reply With Quote
Old 10-07-2013, 12:51 PM   #2
Default Re: 4PLS help
I just got one also and look in the xr10 section and look and Harley's setup it's close to the 4pls. If you have the manual handy that helps a lot. The radio is awesome.
Diablo666 is offline   Reply With Quote
Old 10-07-2013, 12:54 PM   #3
Yes both esc's need to be hooked up. I put mine on channel four like manual said to do.
Old 10-07-2013, 12:55 PM   #4
1-The radio needs to be set up for dual ESC's and the rig.
2-You need to calibrate the ESC's to the RX (once step 1 is done).
Charlie-III is offline   Reply With Quote
4PLS help - Similar Threads
Futaba 4PLS vs Airtronics MT4 aqwik69 Electronics 3 10-30-2013 12:34 PM
Futaba 4PLS Binding Issue? hpiguy Electronics 5 09-25-2013 01:29 PM
Issues linking 4PLS to receiver 12vctd Electronics 3 08-17-2013 03:26 PM
Futaba 4PLS in Stock RPP Hobby RPP Hobby 0 07-08-2013 04:57 PM
Futaba 4PLS SuperRoo Electronics 3 03-23-2013 07:43 PM
