11-17-2013, 09:36 AM | #1 |
Quarry Creeper Join Date: Mar 2006 Location: Pewee Valley, Kentucky
| Antenna placement or lack of
I've been out of the RC scene for about 15 years but just got back into it with an Axial Wraith. I've noticed in most pics of crawlers that they aren't running antenna's. Where is everyone running their antenna wires if they aren't running it straight out the top?
11-17-2013, 10:02 AM | #2 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
| Re: Antenna placement or lack of
The newer 2.4ghz systems don't require the long antennas like the am radios back in the day. Most new receivers only have short 3-4" antennas coming out of them, and most guys just tuck them away under the body.
11-17-2013, 10:16 AM | #3 |
Mine is a JR XR3 FM, not sure what ghz it is.
11-17-2013, 10:20 AM | #4 |
RCC Addict Join Date: Aug 2011 Location: Elkhart
| That's a 27mhz fm radio, so your receiver will have a longer antenna, as stated above most people run 2.4 ghz now ( no need for long antenna on receiver or transmitter) 2.4 is newer technology If you plan to use that radio you have you will have to run antenna out the top for best signal, or upgrade to a 2.4ghz ( recommended ) I prefer 2.4 all day long myself Last edited by 1r3land; 11-17-2013 at 10:24 AM. |
11-17-2013, 10:25 AM | #5 |
Great, thanks for the info guys!
11-17-2013, 10:38 AM | #6 | ||
| Re: Antenna placement or lack of Quote:
The newer 2.4ghz radios have short antennas. They are also a bit more immune to "noise" from the outside, things like the brushes on the motors. That is why you HAD to run caps on the brush hoods to kill most of that noise. One good thing about AM & FM though, the signal travels through water BETTER than 2.4ghz. So if you run a rig that will spend time in deeper water, you "may" want to keep that radio. It appears that 2.4ghz signals die off if the antenna is more than 1-2" deep in water. [@ 1r3land..... isn't 27mhz AM & 72mhz FM?] [@ Jeff@TireBalls, your radio is either ~0.27gz or 0.72ghz if I did it correctly.. Also a lot of the newer radios have the ability to save settings for more than 1 rig, thus easier to swap between rigs without twiddling dials to get things set-up correctly.] Last edited by Charlie-III; 11-17-2013 at 10:40 AM. | ||
11-17-2013, 10:44 AM | #7 | |
That's good to know. I'm going to run my JR for now and save up for a new one after Christmas. | |
11-17-2013, 11:42 AM | #8 |
Agreed, antennas are very short nowadays. Ever since going to 2.4, I've coiled up my antenna in the rx box and never had an issue. Unless getting about 30yds away, which is a rarity for this niche of rc. The cheaper 2.4 radios today aren't bad. 20-30bucks can get a cheap and reliable 2ch radio, if thats the only requirement. |
11-18-2013, 03:20 AM | #9 |
Quarry Creeper Join Date: Nov 2005 Location: Western, NC
Futaba even makes RX's that don't have an external antenna now, known as BIA for built in antenna. Once Charlie-III helped me get them bound to my radio, I love them, and I'm running them in two of my rigs now.
12-02-2013, 02:19 AM | #10 |
Some more details on antenna length: It's based on the carrier wave's length, which is inversely proportionate to the frequency. A 27MHz wave is ~11m long. The typical antenna used for RC cars is ~35cm (the tube length) or 1/32 wave. If the length isn't exactly 1/32 wave, but a little longer/shorter the reception will be considerably decreased. For my old Holiday Buggy I use a ~1/16 antenna, which gives good range. 2.4GHz waves are ~12cm i length, and the antennas used are typically 1/4 wave. It's the outer 3cm or so of the Rx's cable that is the actual antenna. It's less sensitive to small variations in antenna length. I have my antenna (the slightly curved light grey bit) at the rear of the truck, just underneath the body, to avoid interference from the other electronics. |
12-02-2013, 03:13 AM | #11 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
The receivers I use have internal antennas...nothing sticks out.
12-02-2013, 04:52 AM | #12 |
When I used to race carpet before we had 2.4ghz radios we used to wrap the antenna through a piece of lexan underneath the body like this: |
12-02-2013, 09:50 PM | #13 |
| Re: Antenna placement or lack of |
Antenna placement or lack of - Similar Threads | ||||
Is this from the lack of a BEC? | ProfitOfDoom | Electronics | 15 | 10-10-2013 12:07 AM |
Antenna Placement | hdale | Electronics | 1 | 06-02-2009 05:58 PM |
Lack of power | CronusTRD | Electronics | 25 | 12-19-2008 04:04 PM |
Lack of Consent | cheapjeep2 | Chit Chat | 23 | 09-26-2006 04:15 PM |
Anyone replaced the metal antenna with an antenna wire? | greenone | General Crawlers | 6 | 01-31-2006 09:17 PM |
