02-15-2014, 06:39 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: Westfield
| Throttle cutting out while steering.
Just got my G6 kit together. Used my AE2 outta my basher and soldered a rc4wd 35T motor to the esc. Brand new HK metal gear servo 260oz @ 6v. Wired it all up, and it cuts out at full throttle while steering. Means the servo isn't getting enough juice? or visa versa? |
02-15-2014, 06:46 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: Throttle cutting out while steering.
You need to wire in a BEC. http://www.rpphobby.com/product_p/cse095-0022-00.htm Last edited by Norton; 02-15-2014 at 07:02 PM. |
02-15-2014, 06:48 PM | #3 |
The weird thing is. My basher has the same servo. But never did it. But I was using the axial 27t, which is the only difference.
02-15-2014, 08:04 PM | #4 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
Possibly getting close to cut off voltage on the battery?
02-15-2014, 08:27 PM | #5 |
Tried different batteries. I'll try my Axial receiver instead of my new flysky one (the one that supports higher voltage) and see what happens
02-15-2014, 09:01 PM | #6 |
Oh maybe it's an ABS setting on the transmitter? Are you running the throttle channel in reverse by chance ?
02-15-2014, 10:44 PM | #7 |
Rock Crawler Join Date: May 2012 Location: Washougal
BEC and be done with it |
02-16-2014, 06:13 AM | #8 |
I will try fiddling with the settings. Throttle might be reversed, and will check the ABS. I think it copied the settings from my SCT.
02-16-2014, 06:46 AM | #9 |
No ABS, but no matter what i do, i have to set both channel 1 and 2 to REV, otherwise NORmal is backwards.
02-16-2014, 09:55 AM | #10 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
No juice when turning is called a brownout, due to AE2 not being able to supply consistent power. A BEC or powering servo independently is your solution. |
02-16-2014, 10:09 AM | #11 |
| Re: Throttle cutting out while steering. |
02-26-2014, 06:46 PM | #12 |
Just got my HH Esc and Motor, and the servo was still causing brown outs without a BEC. So i decided to try my basher's servo, which is the same exact servo but older. And not a SINGLE brownout. I think I will email Hobbyking and arrange a possible replacement. I know, I know, I will still get a BEC later on, just can't afford it after spending 800 bucks on this rig :P
02-26-2014, 09:00 PM | #13 | |
Rock Crawler Join Date: Mar 2011 Location: USA
| Re: Throttle cutting out while steering. Quote:
It worked fine ,,Low voltage servo,,Wasnt getting the throw out of the servo arm ,,blue shorty,, So I went with a CYS S2215 HV ,,Dang servo went ,jittery ,bad throttle response,steering cut out ,,Added new BEC cleaned it up and can use 3s ,,Works great ,,,HV servo's need BEC , When I turn one into a winch the board is gone so dont matter much ,,I would say it lays in the board,needing the higher voltage ,,, | |
02-26-2014, 10:51 PM | #14 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
$800 and you didn't spend $20 on a BEC...
02-27-2014, 03:01 AM | #15 |
Throttle cutting out while steering. - Similar Threads | ||||
Steering no throttle | moejean | Axial SCX-10 | 9 | 03-31-2013 12:33 AM |
rs pro cutting at full throttle | joss097 | Electronics | 6 | 02-16-2013 03:16 PM |
Throttle cutting out on XR10, but not steering? | generalee7 | Electronics | 11 | 12-01-2011 10:04 PM |
Steering but no throttle | 2JSC | Electronics | 16 | 05-09-2010 12:18 AM |
