09-08-2014, 06:05 AM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
| Tekin RS Gen 2 calibration issues
I'm having problems trying to get my RS Gen 2 calibrated with my MT-4 radio. I've gone through the calibration procedure many times, step by step. When I go through the calibration process, the RSG2 will see full throttle pretty quick, neutral within a couple of seconds, but at full brake/reverse, it takes it at least 10 to 15 seconds to see full brake. Sometimes it doesn't see full brake at all. I have my throttle EPA's set at 150, both throttle and brake. I do not have any ABS or brake mixing functions turned on, on the MT-4. I've never had an issue with calibrating the RSG2 with my MT-4. It usually finds all 3 points very quickly!!! The esc and rx is out of a stadium truck that I used to race. I have the throttle set to normal in the radio, and my motor set to reverse in the esc. It's in my SCX10 Jeep Rubicon - motor and tranny are not mirrored. Any help or input would be greatly appreciated!!! Sent from my modded TI-83 plus. |
09-08-2014, 06:27 AM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: Tekin RS Gen 2 calibration issues
You should be calibrating with Throttle EPA's at 100, not 150. Additionally, have you tried reversing the Throttle channel. I know on my 4PK it can get picky about this on certain ESC's I've used to get them properly calibrated. |
09-08-2014, 07:01 AM | #3 |
I've tried the EPA's at 100, and it's the same, or worse. I was wondering if I should set the motor back to normal rotation in the esc, and reverse the throttle on the radio. I may try that when I get home this afternoon. Sent from my modded TI-83 plus. |
Tekin RS Gen 2 calibration issues - Similar Threads | ||||
flysky gt3b and wraith calibration issues. | TrailonRails | Electronics | 6 | 07-04-2014 07:39 PM |
Mmp calibration issues | idk | Electronics | 9 | 03-03-2013 08:16 PM |
CC SW and 3pm-x calibration issues | stewbaru | Electronics | 3 | 08-30-2010 11:29 PM |
Tekin fx-r radio calibration help!! | the02stangman | Electronics | 6 | 11-20-2009 01:07 PM |
