04-16-2015, 04:47 PM | #21 |
| Re: When a BEC is required
Got any numbers to prove that?
04-16-2015, 04:56 PM | #22 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
81,843 RCC members can't be wrong. Probably 81,844 by the time this posts. |
04-16-2015, 06:57 PM | #23 |
Who needs a BEC? Receiver packs 4 life! Only the finest 4 cell alkaline holders for me. |
04-16-2015, 07:27 PM | #24 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
Quote "When a BEC is required" When ever you have to ask that question...........!! |
04-16-2015, 09:36 PM | #25 |
Quarry Creeper Join Date: Sep 2009 Location: Scottsdale
We should sticky this
04-16-2015, 10:36 PM | #26 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: When a BEC is required |
04-16-2015, 10:37 PM | #27 |
I want more for a sticky. Is this the pinnacle?
04-16-2015, 10:44 PM | #28 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
I imagine 1000 guys all watching as one of them decides to walk up and piss on the electric fence. After his pecker blows off those watching say to themselves " I am not going to piss on that fence". Then here comes that one guy who swears there is not enough amperage to make his wiener explode and pisses on the same fence. Then while he is picking up the pieces of his blown off dong he thinks it must have been an anomaly.
04-16-2015, 10:55 PM | #29 |
Amperage to make my weener explode? Sounds interesting. |
04-16-2015, 11:10 PM | #30 |
04-17-2015, 01:22 AM | #31 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
Back to the original question after a brief break for shenanigans... You need a BEC when your electronics cut out from going lock to lock once with a high power servo. (300 oz/in @.08 sec in a 4x4 sct with an sv3) You also will need a BEC when you run a really low power servo (hs-645mg) with an extra half amp or so of lights. At this size of vehicle, electronics calculations are more points of reference than things to do hard math with (vs a full size vehicle, where loads are more predictable and thus can be more accurately calculated). As I know from running my sct, constant vs. burst current varies greatly and both can sometimes be disconcertingly large quantities (puffing a 90c 4600mah, about 400amps burst; about 25-30 amps constant, giving ~10 minutes runtime completely at WOT). Being on the edge yet within the margin mathematically often doesn't work out in the real world. Basically, use the math for general reference but not for determining specific limits (exactly how powerful of a servo can I put in before needeing a BEC?). |
04-17-2015, 07:12 AM | #32 | |
| Re: When a BEC is required Quote:
there goes another one | |
04-17-2015, 07:25 AM | #33 |
Newbie Join Date: Apr 2015 Location: newport
is a bec a must when running four wheel steering?
04-17-2015, 07:34 AM | #34 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
^^^ really.......its simple! When you get a rig make a bec part of the deal. I like the blown off pecker comparison it seems fitting with this topic!!! "A bec is like a sore dick ya cant beat it".......(STICKY) |
04-17-2015, 07:36 AM | #35 |
04-17-2015, 07:38 AM | #36 |
04-17-2015, 07:48 AM | #37 |
04-17-2015, 09:57 AM | #38 |
| Re: When a BEC is required If you need one for 2 wheel steering, logic says you need one for 4 wheel steering. If you have 4ws you should consider 2 BECs if they are both good servos. Guido has 3 BECs: one for the front steering, one for the rear steering, and one for the winch. |
04-17-2015, 10:20 AM | #39 |
Quarry Creeper Join Date: Sep 2009 Location: Bay Area
Glad I caught this thread! I hadn't given BEC's a second thought before, but I just threw one in (along with a Castle Link) with my order at RPP for my TF2 build. I'm only going to be running a ~200 oz-in Savox servo, but will be using a second servo for shifting. Plus I want to put lights on it if I ever hack my radio for my channels. I should get one for my Yeti at some point, but that things got bigger problems than a lack of a BEC. It's not moving under its own power for a while. |
04-17-2015, 10:51 AM | #40 |
| Re: When a BEC is required thanks I just purchased castle link programmable BEC I will be installing them some time today
When a BEC is required - Similar Threads | ||||
Bigger BEC required? | Trxvy | Electronics | 7 | 12-05-2013 05:04 PM |
Lathe not required | crawlerhawk | Tools, and Procedures | 15 | 08-09-2012 11:29 AM |
Tziworld BEC-RX Adapter - Your Input required | Tzi | Electronics | 14 | 08-02-2012 03:46 AM |
help required,,,, | b16bazza | Axial AX-10 Scorpion | 7 | 02-17-2009 06:30 PM |
