07-19-2015, 04:34 PM | #1 |
RCC Addict Join Date: Jul 2006 Location: barstow
| Holmes BLE reverse problem in a yeti ?
this may not be a problem at all but the Holmes tech thread is closed for help. i have a BLE and a pro puller installed in my yeti. i can not get the esc to program with the radio switch on my 4pk in the standard position. i have to reverse the switch to get it to program.
07-19-2015, 09:02 PM | #2 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| Re: Holmes BLE reverse problem in a yeti ?
If you've got a castle link, plug it in and see if you can reverse the motor direction. I wish I was more help, but I don't have one (BLE) yet. If it still has a stock axle, maybe, and its a stretch of a maybe, but you could try flipping the ring gear....I'm not sure if there is enough room, but maybe...... The only thing I know for sure is, when people buy curries, sometimes they have that issue, since the ring gear can only be fitted on one side of the pumpkin, they end up having to reverse their motors. Last edited by Alexander_0_1; 07-19-2015 at 09:11 PM. |
07-19-2015, 09:56 PM | #3 |
Quarry Creeper Join Date: May 2015 Location: RRW
I think you can flip the ring gear. Some guy came into my LHS with 1 axle turning one way and the other axle turning the opposite way. He installed the ring gear wrong. But I'm thinking his was a wraith...I can't remember now :(
07-20-2015, 09:42 PM | #4 |
Quarry Creeper Join Date: Sep 2012 Location: Seattle, wa
You have to reverse the throttle in futaba transmitters to calibrate the esc.
07-20-2015, 10:51 PM | #5 |
| Re: Holmes BLE reverse problem in a yeti ? |
07-20-2015, 11:16 PM | #6 | |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Holmes BLE reverse problem in a yeti ? Quote:
07-21-2015, 07:45 AM | #7 |
Newbie Join Date: May 2015 Location: Greenville, SC
In my experience with my 4PLS, Futaba's throttle channel needs to be reversed for what we consider "normal" operation. (Meaning, pull trigger = go forward & push trigger to front = go backwards)
07-21-2015, 11:44 AM | #8 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
It's a given reality for ANY futaba radio and Castle ESC (not sure on others). Since HH ESC's are based on Castle hardware and firmware, the same applies. You have two options. 1. Calibrate with your radio throttle on reverse, then go into Castle link and reverse motor direction at the ESC. DO NOT, I repeat DO NOT just flip the red and black (A and C wires). 3 phase doesn't work like a brushed motor. 2. Flip the ring gear to the other side on both the front and rear diff. On the Exo terra housing (same as a yeti) and the wraith axle housing (same as a yeti) you can flip them to get the wheels turning the right direction. I recommend going with option 1. The esc led should show green in forward and red in reverse. If you just flip the gears it won't. I don't expect this hurts anything. But if you haven't been into the esc in castle link you may not have both forward and reverse directions set at 100%. Last edited by dna4engr; 07-21-2015 at 11:46 AM. |
Holmes BLE reverse problem in a yeti ? - Similar Threads | ||||
yeti stayed in reverse | Baggednissan88 | Axial Yeti | 11 | 05-04-2015 08:32 AM |
Holmes Hobby br-xl won't go in reverse | raiders32 | Electronics | 7 | 12-27-2012 01:38 PM |
Reverse problem | calikingcrawler | Axial AX-10 Scorpion | 3 | 03-14-2009 04:28 PM |
