08-01-2015, 06:06 PM | #1 |
Pebble Pounder Join Date: Jul 2007 Location: Reedsburg
| bec issue
i have a tf2 with a tekin fxr and a cc bec and a solar shift servo and a turnagy steering servo now my issue is i have no steering when i plug my battery in but if i unplug the bec and plug it back in i have steering and im good to go but i cant just plug in the battery and have steering why
08-01-2015, 08:09 PM | #2 |
RCC Addict Join Date: Aug 2009 Location: Earth?
| Re: bec issue
Short? Check wiring.
08-01-2015, 09:04 PM | #3 |
| Re: bec issue
It's just when I first plug it in and after I unplug the because and plug it back in every thing works like it should and until I shut the truck off
08-02-2015, 03:56 AM | #4 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
| Re: bec issue
How is the bec weird? Directly to the servo or through the receiver? If through the receiver did you pull the power wire from the esc plug that goes into the receiver?
08-02-2015, 09:31 AM | #5 |
| Re: bec issue
through the receiver and yes i pulled the red wire on the esc
08-02-2015, 11:37 AM | #6 |
| Re: bec issue
wire the servo direct as suggested earlier and see if the issue is still there...it could be a bad rx
08-03-2015, 06:42 PM | #7 |
| Re: bec issue
How do I wire it direct when I have two servos? One steering and one shifting
08-03-2015, 06:57 PM | #8 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
| Re: bec issue
I believe both power wires would go to the BEC.
08-03-2015, 07:16 PM | #9 |
| Re: bec issue
I would try it with the shift servo temporarily disconnected....wire the steering servo direct....or just try it normal with the shift servo unhooked....
08-04-2015, 12:17 PM | #10 |
Quarry Creeper Join Date: Sep 2010 Location: Central MN H-Town
| Re: bec issue
What is the ccbec voltage set to? I just had the same problem and increased the voltage from 6.0 volts to 6.5 volts and that solved the problem with the servo.
08-04-2015, 01:09 PM | #11 |
| Re: bec issue
ok i will check it out this weekend when i have a few min and get back to you guys
08-22-2015, 09:32 PM | #12 |
| Re: bec issue
well ended up selling the truck before i could look into anything got an cash offer that i couldn't refuse
bec issue - Similar Threads | ||||
Is this a BEC issue? | Lex07 | Electronics | 4 | 11-11-2014 05:59 PM |
Castle BEC issue | rmb2485 | Electronics | 4 | 04-20-2012 02:37 PM |
Issue with Castle BEC | du4x4 | Electronics | 13 | 02-21-2011 02:57 PM |
bec issue | demonoid369 | Newbie General | 5 | 12-16-2010 04:36 PM |
BEC/ESC-- Issue. | dirk379 | Electronics | 7 | 09-29-2010 11:46 AM |
