09-24-2015, 08:53 PM | #1 |
Newbie Join Date: Jun 2015 Location: Right their !!!!
| HH esc getting hot ??
Holmes Hobbie, 13 turn torquemaster, bec, gearing is 56/10 32 pitch and 3 cell lipo, esc getting hot 170 temp after 1/2 hour of crawling but cruising down trails it around 70 deg , both checked with temp gun. Checked motor crawling and cruising around 80 deg. Would gearing down even more help with esc temp, or should I change motor ? Also this set up is in a wraith.
09-25-2015, 12:26 AM | #2 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
| Re: HH esc getting hot ??
Do you use the internal BEC or an external one... HH ESC have some problems with their internal BEC |
09-25-2015, 07:04 AM | #3 |
| Re: HH esc getting hot ?? |
09-25-2015, 07:17 AM | #4 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
13t Torquemaster or Crawlmaster? If TM I'm surprised that hasn't gone up in smoke yet. 13t TM is completely the wrong motor for a Wraith. Be hard to get a low enough spur/pinion ratio for that. |
09-25-2015, 08:35 AM | #5 |
09-25-2015, 09:59 AM | #6 |
| Re: HH esc getting hot ?? I have the torquemaster , and will be changing to the crawlmaster , should the gearing be fine
09-27-2015, 09:04 AM | #7 |
Gearing will be great with Crawlmaster, could possibly even go up a couple on the pinion but check motor temps.
HH esc getting hot ?? - Similar Threads | ||||
esc getting too hot?? | broncocrest | Axial AX10 2nd-gen | 5 | 05-17-2014 09:07 AM |
esc getting hot | metalking | Electronics | 4 | 01-13-2014 09:43 AM |
esc getting hot | mikeman84 | Electronics | 10 | 05-24-2011 02:04 PM |
esc getting HOT! | 2500hdon37s | Electronics | 5 | 04-23-2009 03:45 PM |
ESC getting HOT! | Mekong | HPI Wheely King | 15 | 06-29-2007 08:22 AM |
