05-11-2017, 08:09 PM | #1 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
| Servo throw or travel
I have a brand new HH HV 500 servo. When building my custom leafed ascender, I was manually moving the servo by hand from lock to lock which is about 180degrees. I don't need 180 degrees from full left to full right. But, when I finally powered the rig, I've only got about 90 degrees of throw at the servo from full left to full right. I've got a spektrum dx4c radio, and even with the steering travel maxed out at 150% both left and right, that's all I've got for servo travel. What's up with that? I set the suspension and steering up based on what the servo can physically turn by hand and was expecting that. My front axle is custom and can get well over 45 degrees of tire turn but now I'm lucky to get old school scx10 steering. WTF!!?? Any help would be great. Thanks. Ben |
05-11-2017, 08:18 PM | #2 |
| Re: Servo throw or travel
Upside down ? Flip the arm over does it have more ? Hang up and Drive |
05-11-2017, 08:28 PM | #3 |
Rock Crawler Join Date: May 2013 Location: Uniontown
I was going to ask if the servo without horn is as limited but I think Mike is thinking the same thing I am Sent from my XT1585 using Tapatalk |
05-11-2017, 08:55 PM | #4 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Servo throw or travel Quote:
Ernie | |
05-11-2017, 09:02 PM | #5 |
Like re-bind it to the receiver Ernie? I haven't done anything except almost smash the whole truck and walk away. I'm so bummed it isn't even funny. There is no binding of any type. Even with no horn, the servo only has about 90degrees total throw. Haven't tried another servo yet. I guess I'm asking if any of you can get the same throw out of servos when powered up as when you turn them by hand unpowered if that makes any sense. You know how there is a pin on the output gear of the servos to keep them from going round and round? Should be able to damn near hit that pin with endooints adjusted to max I'd think. Ben |
05-11-2017, 10:38 PM | #6 | |
Just set everything on your work bench, tell it good night and walk away for the night. I think you should be able to go at least 150 with it turned on. Good luck my friend, bring us up to date tomorrow! Ernie Last edited by CODYBOY; 05-11-2017 at 10:55 PM. | |
05-12-2017, 05:59 AM | #7 |
I see you checked the endpoints on the radio but also check to make sure the dual rate on the steering hasn't been turned down by accident.
05-12-2017, 07:37 AM | #8 |
| Re: Servo throw or travel |
05-12-2017, 07:46 AM | #9 |
| Re: Servo throw or travel Dual rate basically reduces both endpoints by a percentage simultaneously, it is assigned to the D lever on the DX4C by default. Make sure it is turned up to 100% for full throw.
05-12-2017, 07:59 AM | #10 |
05-12-2017, 08:28 AM | #11 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
I am not sure if the HH servos can be programed, I know most Hitecs can be. If you know anybody with a servo programmer see if you can open up the range of travel with it. A lot of servos are capable of 180* of travel but are programmed at the factory for far less. If all else fails you can put a longer arm on the servo or a shorter arm on the knuckle(or drill a hole closer to the knuckle). This will make your steering throw greater but you will loose a bit of torque. |
05-12-2017, 09:20 AM | #12 |
Have you called or emailed Holmes? Hang up and Drive |
05-12-2017, 10:22 AM | #13 |
If nothing helps that you guys have mentioned, I will call Holmes to see what can be done. Just wanted to see if I wasn't missing something simple. Thanks again guys! Ben |
05-12-2017, 02:03 PM | #14 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
This isn't the first time I've heard this happening with a holmes servo. Try longer steering arms or longer drag link first. If those don't help, longer servo horn but that's the last resort.
05-12-2017, 09:56 PM | #15 |
So, after rebinding, checking the steering rate on switch D, swapping out servos with another good used one, bypassing BEC, I still have only about 90 degrees of servo travel full left to full right. I've never tested or had an issue on another truck so I don't know if throw is the norm but my mind is blown. Why have a servo that is mechanically able to rotate 180 degrees yet only do half that on its own. Damn. Ben |
05-13-2017, 02:34 AM | #16 | |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
Sent from my SM-N920V using Tapatalk | |
05-13-2017, 06:11 AM | #17 |
Pebble Pounder Join Date: Mar 2016 Location: GC
Sounds like the steering throw is limited in the servos programming. I bought a brand new Hitec that was limited down to about 60 degrees of throw last year out of the box. I hooked it up to my hfp-30 and restored full throw.
05-13-2017, 10:35 AM | #18 |
| Re: Servo throw or travel SHORTER Steering arms require less throw from the servo. The longer the steering arm the more it has to move to acheive full lock to lock.
05-14-2017, 05:37 PM | #19 |
Well, no dice with all of the tips. I sent an email in to Holmes Hobbies to see what they say. I'll let you all know how it goes. Ben |
05-20-2017, 12:05 PM | #20 |
SO heard back from Holmes Hobbies and they said that it's standard for servo's to only turn 90 degrees under their own power. HH servo's can't be programmed to turn more than what they do. So that sucks in my book anyway. I know I'm new and have to learn things the hard way but for anyone out there who's building a custom rig, you'd better set up the steering last, because you need the servo to be powered to see how much throw it actually has under it's own power, not what it can physically move by hand.
Servo throw or travel - Similar Threads | ||||
Servo throw | billy bones | Electronics | 4 | 05-24-2015 09:26 PM |
Servo throw. | billy bones | 1.9 Scale Rigs | 4 | 05-24-2015 04:04 PM |
servo throw | desertrunner | General Crawlers | 2 | 05-27-2010 04:47 PM |
any more throw out of a servo? | topdog909 | Electronics | 14 | 07-24-2008 07:28 PM |
servo throw | chrispbubba | Electronics | 10 | 10-29-2006 12:43 PM |
