08-16-2017, 08:51 AM | #1 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
| 1/5 scale BEC wiring question
I need some help on wiring up a BEC in my Kraken Vekta5 that is converted to electric power. I have the below ESC and it has wiring for two 4S batteries. I need to wire in my BEC for my servo that has a max input voltage of 8.4V. If I splice into the top/left set of battery leads into the ESC will I just be getting (1) 4S battery power into the BEC? I am concerned with frying it since the Castle BEC is only rated to 6S, but I will have 8S power coming into the ESC. Thanks Wes |
08-16-2017, 08:57 AM | #2 |
| Re: 1/5 scale BEC wiring question
As long as you tap off one side only you will be fine. Hang up and Drive |
08-16-2017, 09:21 AM | #3 |
Thanks, I was just confused since it is daisy chained like that for the ESC, dont want to fry the BEC right away. Wes |
08-16-2017, 09:25 AM | #4 |
Yup. I normally wire directly into the esc leads, but if you do that as you said poof ! Hang up and Drive |
08-16-2017, 10:13 AM | #5 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
What I do now on all my bec installs is put it up about 2" from the board. Cuts down the wiring at the plug. And it'll work for you too since theres just the 2 wires there.
08-16-2017, 11:10 AM | #6 | |
| Re: 1/5 scale BEC wiring question Quote:
Im planning to use a voltmeter and plug in some charged batteries and triple check that what Mike confirmed above will work. Wes | |
08-16-2017, 11:27 AM | #7 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
You could feed it off the balance lead of one battery so you dont have to touch the ESC wires.
08-16-2017, 12:20 PM | #8 |
| Re: 1/5 scale BEC wiring question |
08-16-2017, 01:51 PM | #9 |
08-16-2017, 02:07 PM | #10 |
Pebble Pounder Join Date: May 2014 Location: Williston, ND
Be absolutely sure that you wire it off of the correct battery. You want the negative input of you BEC to be on the most negative battery. In your picture it would be on the battery plugged into the top left plug. If you wired into the other battery you would be hooking you BEC up to a negative that's actually referenced to the other battery, so your negative lead is actually 14.8V already.
08-17-2017, 02:34 PM | #11 | |
1/5 scale BEC wiring question - Similar Threads | ||||
Bec wiring question | jwall046 | Newbie General | 3 | 08-03-2014 01:00 PM |
CC BEC Wraith Wiring Question | Pita | Axial Wraith | 4 | 04-23-2013 11:27 AM |
Wiring BEC Question | doc.hamilton | Electronics | 6 | 02-14-2013 01:20 PM |
Castle BEC wiring question | Full_Throttle | Electronics | 9 | 12-26-2011 07:37 AM |
CC BEC wiring question... | shelljeep | Newbie General | 3 | 01-21-2011 09:06 AM |
