12-19-2017, 12:19 PM | #1 |
Quarry Creeper Join Date: Mar 2007 Location: winchester
| servo not moving smoothly
So my friend had an extra servo still in the box and I needed one for my wraith since my tactic finally crapped out. so I figure what the hell ill try it out. after looking at the specs I figured this thing must pack a decent punch but when I am steering the wraith its not smooth at all! its jumpy when traveling from endpoint to endpoint. this servo is rated from 6v to 8.4v. based on my research I'm pretty sure this thing is power hungry and running this thing from the AE5 isn't going to cut it. so my question is.... what should I do Link for Servo 1. add a cap on the receiver which is supposed to help regulate the pull of current or 2. get a CC BEC just for the servo, tune it to the 8.4v it can handle and let it rip I think both of these will solve my problem but figured it wouldnt hurt to get some opinions on here. TIA Last edited by intheworks; 12-19-2017 at 12:22 PM. |
12-19-2017, 12:48 PM | #2 |
Quarry Creeper Join Date: May 2017 Location: Devon
| Re: servo not moving smoothly
Yes you need a BEC. There's a post somewhere hereabouts pointing people in the right direction Sent from my Pixel using Tapatalk |
12-19-2017, 01:04 PM | #3 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
I often just use a Racers Edge Glitchbuster. It’s a power capacitor. Should smooth things out. I generally run them with my high torque servo’s when I upgrade my rtr’s |
12-19-2017, 04:50 PM | #4 |
its somewhat of a cheap ervo so it will be choppy
12-19-2017, 06:04 PM | #5 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
I'd get an external BEC, upgrade your ESC to one with a better internal BEC, or run your servo straight off 2S.
12-19-2017, 06:18 PM | #6 |
| Re: servo not moving smoothly |
12-19-2017, 06:19 PM | #7 |
12-20-2017, 06:19 AM | #8 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
I'm inclined to think there's something else going on. Sure, that servo is probably power hungry, but it shouldn't be sucking that much current just turning it back and forth with no load. Sure, when you're bound up on the rocks it can suck a lot, but not just turning back and forth on a table. I would pop the servo arm off and move your steering back and forth by hand to make sure everything is smooth, and also turn the servo back and forth with it disconnected to see how smooth it is on its own. You can also wire it directly to 2S (since it's safe at 8.4v) and see if it's smoother. I'm guessing that the servo might just be notchy, or something is bound up in your steering.
12-20-2017, 06:23 AM | #9 |
I read that the internal BEC output can be under 6v even though that's what is rated so if its underpowered it would make sense since it is a high voltage servo but I do agree I need to take off my linkage and make sure everything is smooth. Question though instead on running a second battery just for the servo and trying to be cost effective does anyone have experience with one of these pre programmed UBEC units? if these are any good I would get this for my solar d772 and then use ccbec I have on my bully2 for this higher voltage servo and push the full 8.4V https://www.banggood.com/AEO-X7-Pro-...r_warehouse=CN |
12-20-2017, 06:32 AM | #10 |
I wasn't suggesting that you run a 2nd battery for the servo, but just temporarily hook it to 2S as a method of diagnosing its functionality. With respect to those UBECs, I've got a couple here that I've been meaning to test, but I haven't gotten to them yet. Based on their design, they won't provide the continuous current that they're claiming, but they should be able to do it in bursts, which is all you really need for a servo anyway. I'm going to try one of those 7.2v versions on my Gen7. The servo works great with no brown outs on the stock ESC, but I want to raise the voltage to make it a little faster. |
12-20-2017, 06:53 AM | #11 |
Gotcha okay I got a 2s I can use for that. I’m gonna go through it and see what I can find. If anyone else has some feedback on the ubec that’d be cool. Thanks
servo not moving smoothly - Similar Threads | ||||
Rebuilt axels, now not spining smoothly? | BigJonny | Team Losi Comp Crawler | 1 | 04-16-2011 11:13 PM |
servo moving when using throttle | JesterSpec | Electronics | 7 | 01-31-2010 01:04 PM |
CR-01 problem: wheels not turning smoothly. | PumpkinPie | Tamiya CR-01 | 2 | 01-01-2009 02:14 PM |
Moving the servo wire out of the way MOD | mysharona | Electronics | 2 | 08-01-2008 06:19 PM |
The rest of the componenets for moving the servo | kelly_and_brian | HPI Wheely King | 1 | 02-23-2008 12:23 AM |
