Thread: Hobbywing 1080 esc
Old 03-18-2019, 01:36 AM   #1
Default Hobbywing 1080 esc
I just finished building my new trailfinder2, I'm using a quick run 1080, but when I bound the truck, the throttle was reversed and it is low speed forward, high speed reversed, so I switched the throttle reversed, and now forward and back are correct, but it's still slow forward and fast in reverse. Any thoughts? I have checked all my wiring, it's all correct. I'm using a dx4c transmitter. Your ideas will be much appreciated.
Bjorn is offline   Reply With Quote
Old 03-18-2019, 02:15 AM   #2
Default Re: Hobbywing 1080 esc
You should have swapped the motor wires instead of throttle reversing.
Anyway, you can set the rev speed to 100% using the program card and bam, done. If you don't feel like swapping the leads.
Ninomaniac is offline   Reply With Quote
Old 03-18-2019, 12:36 PM   #3
^^^ What he said. I had the same issue once. Flip the motor wires is best.
BIGW0RM is offline   Reply With Quote
Hobbywing 1080 esc - Similar Threads
Hobbywing Quicrun Waterproof 1080 Brushed Crawling ESC LSXGMC Electronics 450 06-27-2020 09:06 PM
Anyone using the Hobbywing QUICRun WP 1080 ESC? CoolRunning Electronics 143 04-28-2020 08:48 AM
Hobbywing 1080 esc programming issue CRAWLIN5150 Electronics 2 06-19-2018 11:05 AM
HobbyWing 1080 settings. Oh How Original Electronics 3 04-04-2018 06:37 AM
Hobbywing 1080 krazee Traxxas TRX-4 2 12-21-2017 09:03 PM
